DIY Headlight (Low Beam) Bulb Change - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 1Likes
post #1 of 20 Old 11-12-2009, 08:06 PM Thread Starter
We have lift-on
Exage's Avatar
Quoted: 86 Post(s)
(Thread Starter)
This is a guide to change the headlight low beam and DRL (bulb) on your 9th Gen Toyota Corolla. This applies to all 9th Gen models and years.
Time: A couple minutes
Parts: Headlight Bulb #9006. Toyota Part #90981-13047. Cost $20-25 per bulb.
Tools: Rubber Gloves
First check which light is out by turning on the headlights (you don't have to turn the key!). Then turn the headlights back off.
Note: If both your low beam headlights are out, check the headlight fuse first.
Note: You don't have to disconnect the battery, however when you remove the lightbulb from the plug I recommend that the headlights are off.
Once you've determined which side is burned out, pop and raise the hood. On my XRS it was the passengers' side. Now look at the rear of the headlight housing from the engine bay.
You should see something like this (passengers' side)
I tagged the headlight and plug but I'll point out some other things in the picture:
Top Left: That's the highbeam bulb and plug.
Bottom Left: XRS ABS Control Unit.
Bottom Right: Windshield washer fluid reservior cap.
To take the bulb out you will need to disconnect the bulb from the plug. You will need to pry the two clips back (on the plug) that are facing towards the engine bay and slip the plug off. I managed by hand...
Pic of the plug in my hand, note the two clips on the plug
Now you can remove the headlight bulb. The headlight bulb is removed by turning it 1/8th of a revolution counter-clockwise. After that you may need to wiggle it back and forth to get it to come out.
Pic of the old bulb on the 2ZZ-GE
Note: DON'T TOUCH THE GLASS PART OF THE NEW BULB. THEY ARE HALOGEN. If you touch it with your bare hands oil/dirt will be transfered to the glass and when the bulb heats up it may explode or have a shorter lifespan.
With any new light bulb: Take your time and be gentle with it, don't drop it!
Putting the new headlight bulb in is just the steps reversed.
The new bulb might be hard to turn 1/8 clockwise... give it a little bit of force if that's the case. Make sure the plug clips snap to the new headlight.
Turn your headlights back on and make sure the new headlight bulb works!
Back to normal again!
Exage is offline
The Following User Says Thank You to Exage For This Useful Post:
Sm0keydaBear (12-28-2010)
post #2 of 20 Old 11-13-2009, 04:02 PM
Quoted: 0 Post(s)
Is essentially how I did it. For me on my 08 LE it is more of a pain on the left side for me to do that one. (right side of car, left if looking at it.)
2008 Toyota Corolla LE 5-speed
2002 Kawasaki Ninja zx9r
02zx9r is offline
post #3 of 20 Old 11-13-2009, 07:02 PM
NMGeorge's Avatar
Quoted: 0 Post(s)
I'd consider changing both bulbs after one blows... It's funny how many times one soon followed the other!
George
2007 Corolla S
USAF 1984-2005
1969 Dart Swinger 340 4 speed
NMGeorge is offline
post #4 of 20 Old 11-13-2009, 07:13 PM Thread Starter
We have lift-on
Exage's Avatar
Quoted: 86 Post(s)
(Thread Starter)
True. The intake snorkel and battery are slightly in the way of the drivers side headlight and plug.
Sorry I misread... you mean the passengers' side was hard to get at?
Exage is offline
post #5 of 20 Old 11-14-2009, 12:11 PM
Quoted: 4 Post(s)
Good job!! Great Info!
05 Corolla LE -AT- 1ZZFE - 136,000 mi
08 Corolla LE -AT- 1ZZFE - 160,000 mi
05 Vibe - AT - 1ZZFE - 135,000 mi.
97 Tacoma - 2WD - 4CYL - 84,000 mi
dorman68 is offline
post #6 of 20 Old 11-14-2009, 09:45 PM
'11 Camry
Quoted: 1 Post(s)
Halogen lamps also dim over time. Not really enough to be noticeable, but when just one is replaced, you can usually tell the difference. It's generally best to replace in pairs.
JasonA is offline
post #7 of 20 Old 12-28-2009, 10:43 PM
Quoted: 0 Post(s)
where do i get the bulb from though? toyota dealer or i could get it from canadian tire? thank you very much!
grandjayson is offline
post #8 of 20 Old 12-29-2009, 02:55 AM Thread Starter
We have lift-on
Exage's Avatar
Quoted: 86 Post(s)
(Thread Starter)
I went to the dealer. The halogen bulb will cost you more money there. I heard some stories about certain halogen bulbs from retail stores burning out after 6 months so I played it safe.
Exage is offline
post #9 of 20 Old 12-29-2009, 07:52 AM
'11 Camry
Quoted: 1 Post(s)
You can get them everywhere. The Toyota bulbs are Sylvania anyway; same stuff you buy at the store. They're about $10/pair at Walmart, AutoZone, Advance, Pep Boys, etc. Any name brand halogen bulb should last YEARS. Even upgraded bulbs (like Sylvania Xtravision) are $18/pair at my local Walmart.
Canadian Tire will sell the bulb.
JasonA is offline
post #10 of 20 Old 12-21-2012, 11:21 PM
Quoted: 48 Post(s)
Dont they require aiming after the bulb change? Does Corolla offer aiming both horizontal and vertical? Can someone jot down how to ?
bmninada is offline
post #11 of 20 Old 12-22-2012, 04:30 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 1557 Post(s)
You don't need to adjust aim after a bulb change since you didn't adjust the reflector.
Aim is adjustable by the 8mm bolts located on the back of each headlight.
My Toyota List:
1982 Corolla SR-5 1JZGTE M/T
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
The Following User Says Thank You to hardtopte72 For This Useful Post:
bmninada (12-22-2012)
post #12 of 20 Old 12-22-2012, 12:46 PM
Quoted: 48 Post(s)
Changing@driver side is a real .... am thinking of taking off the h/assy and doing it... just not enough space! Got the Philips 9012 and modded them to fit the assy. Will post, when done. Any links on how to get the assy off ? I got the bolts off and there's a small plastic hook got that one too , but still the assy refuses to budge!
On a side note - anyone doing it and thinking of doing high and low , should get all the bulbs. Much easier in 1 go. I would love to do the fog lights too into HIR2, but can't seem to figure out how to get to the fog light assy .... next round!
bmninada is offline
post #13 of 20 Old 12-23-2012, 01:29 AM
Archer0T8's Avatar
Quoted: 2 Post(s)
You're probably missing the third bolt, which you need to remove the bumper to get at.
2005 SSM Corolla S
5000k HID Projectors - DC Sports Strut Bar - Pioneer DEH-P9400BH Deck - 2x 300W Polk Subs - Sharkfin Antenna - Black Foglights
Archer0T8 is offline
post #14 of 20 Old 12-23-2012, 06:47 AM
Toyota Fanatic
You don't have an XRS do you?
The drivers headlight is really not hard at all. Even with big hands. On Mazda6 or Prius yes. These cars not really.
Worst case you can simply remove the battery.
My Toyota List:
post #15 of 20 Old 04-02-2013, 07:05 PM
Lost to follow up!
Quoted: 1 Post(s)
iTrader Score: 59 reviews
My son's 07 just blew a Lt low beam headlight last night. He and I both have big hands. I have the bulb I'm thinking I'll have to remove the battery
Tell me more
eyeball96 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
