P1071-System too lean (Check Engine) - Toyota Nation Forum : Toyota Car and Truck Forums
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 18 Old 12-28-2010, 10:23 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Canada P1071-System too lean (Check Engine)
Hi everyone,
I recently had the check engine light show up on my car. Its actully been something on and off for the last 2-3 weeks (it goes away on its own sometimes, or when I fill the gas sometimes)
I took it to two diff. garages I was informed:
1) replace plugs, tune up and throttle body wash,clean MAF sensor---Approx 200
2nd garage) Replace gas intake manifold and clean MAF sensor--Approx 250
I just bought my first car recently and have no experience with mechanics and how to go about dealing with such issues. Any help or feedback as to what you would suggest should be done would be great
Car: 2006 Toyota Corolla
Code: P1071 System too lean
*PS Went to the dealership but they said they dont cover such expenses and would charge 105 just to see the car and say whats wrong..
Also my gas cap when I fill gas has a hole so not sure if the light comes up due to air going through the cap, the mechanic said its fine, that plastic cap is only there for draining any water that goes in..
Thanks for your help!
Cheers
cricmasters is offline
post #2 of 18 Old 12-28-2010, 10:40 PM
Senior TN Member
Quoted: 129 Post(s)
Welcome. Describe the cold idle start up (RPM, engine sounds, tach position, etc) in cold weather compared to a cold start up in the summer or does it only happen in the winter?. How many kms on the car?
mikered30 is online now
post #3 of 18 Old 12-29-2010, 01:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello Mikered..the car has 92,000 km and the start up of the car seems fine similar to summer. I havent noticed any diff. in performance or anything even after the check engine light came on.
The light has only been coming for the past three odd weeks, it wasnt there during summer (when I originally acquired the car)
Thanks
post #4 of 18 Old 12-29-2010, 06:16 AM
Senior TN Member
Quoted: 129 Post(s)
You can buy a can of MAF cleaner for $10 or so and clean it yourself.
See this link on how to clean the MAF: http://matrixowners.com/index.php?showtopic=65513
Might want to check the o ring on the MAF to see if it is deformed. What kind of air filter do you use? Stock intake?
post #5 of 18 Old 12-29-2010, 09:10 AM
Quoted: 4 Post(s)
INtake manifold gaskets are a common issue with the 1zzfe engine. I would replace those.
05 Corolla LE -AT- 1ZZFE - 136,000 mi
08 Corolla LE -AT- 1ZZFE - 160,000 mi
05 Vibe - AT - 1ZZFE - 134,000 mi.
97 Tacoma - 2WD - 4CYL - 84,000 mi
dorman68 is offline
post #6 of 18 Old 12-29-2010, 12:55 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I was looking to do that but just wasnt sure if I would be able to and wouldnt want to experiment on the car.. Ill have a look though into doing that
post #7 of 18 Old 12-29-2010, 01:07 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does the $200 sound right for the replacement of intake manifold gasket?
post #8 of 18 Old 12-29-2010, 02:17 PM
Quoted: 0 Post(s)
$200 to replace the gasket seems high unless that includes a charge for the initial diagnosis.
Toyota rates the intake gasket repair as a one hour job. The intake gasket part costs about $10.
$100-$125 is probably a fairer price for the actual removal and replacement of the itake gasket.
aspen007 is offline
post #9 of 18 Old 12-29-2010, 02:36 PM
Quoted: 1 Post(s)
I would also check the air filter and make sure it is an OEM paper type filter. The K&N type can cause lean conditions in some cars.
2005 Avalon Limited
2006 Corolla
2006 Sienna XLE
2007 Lexus ES 350
2011 Sienna XLE
05Limited is offline
post #10 of 18 Old 12-29-2010, 04:50 PM
Senior TN Member
Quoted: 129 Post(s)
Since you dont have any odd idle issues, I suspect the MAF, although you never said what intake/filter you have. If you clean it and inspect the o ring carefully and the light is still on, test the intake manifold with carb cleaner. There is a chance that your ECU is faulty, did you get the new ECU yet with the recall?
post #11 of 18 Old 12-29-2010, 08:39 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi Mike,
No I am not aware of ECU being faulty, I didnt get a new ECU as I am not aware of any recall. (The previous owner did not inform me of any issues)
I am not sure what kind of air filter I have as well...its the paper quality one from Canadian Tire.
I went to the dealership but they refused to deal with the car and said its not covered by Toyota if the car is older then 60,000 km
post #12 of 18 Old 12-29-2010, 08:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes it is the paper type filter.
Thanks for your rep;y!
post #13 of 18 Old 12-29-2010, 09:02 PM
Senior TN Member
Quoted: 129 Post(s)
Toyota will look at it, you will just have to pay for it.
Well the ECU maybe related to your problem. You can call the dealer and give them your VIN and see if you are eligible to get a new ECU under the recall. The 06s are have an abnormally high failure rate for the ECUs.
http://www.matrixowners.com/tsb/T-EG051-05.pdf
http://www.matrixowners.com/tsb/T-EG006-05.pdf
First step is to clean the MAF with MAF cleaner and see if the light goes off.
The Following User Says Thank You to mikered30 For This Useful Post:
cricmasters (12-30-2010)
post #14 of 18 Old 12-29-2010, 10:37 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi Mike,
Well the check engine light is currently gone, it goes away on its own and comes back every now and there for a bit...
I didnt even know though about the ECU, dont know if that happened to cars that were sold in Canada though...
Thanks
post #15 of 18 Old 02-02-2011, 01:56 PM
AAO
Quoted: 0 Post(s)
Intake manifold gasket -- $5-10
Time it takes to replace -- 45mins to 1 hour
Even if it isn't the problem (yet) you need to replace it because it is an updated part because the old gaskets had corrosion problems or something. Just go ahead and swap it out.
Elmacanite is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
Tags
check engine , corolla , p1071 , toyota
User Tag List
Linear Mode Linear Mode
Back
