P0301 - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
Old 11-28-2012, 10:02 AM   #1 (permalink)
View Jettfixr's Photo Gallery
P0301
My Matrix xrs keeps,popping 0301, I have swapped igniters don't know what to do,next? Shall i just change all injectors or some other parts !!!
Jett
Jettfixr is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:23 PM   #2 (permalink)
Senior TN Member
Gameroom cash: $920718
Did you pull the plugs to inspect? I assume the "igniters" are coil packs?
mikered30 is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:39 PM   #3 (permalink)
View toytec's Photo Gallery
Thats a cylinder #1 misfire code. The cylinder closes to the drive belts.
First try to swap the coil into a diffrent position and see if the code changes ie: p0302 for cylinder #2, p0303 for #3 etc...
Try and swap the spark plug the same way.
The fuel injector would be next but is more difficult for a DUI to swap.
Also check the compression as you may have an internal engine problem.
Good luck.
toytec is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to toytec For This Useful Post:
Jettfixr (11-29-2012)
Old 11-29-2012, 02:45 AM   #4 (permalink)
Good luck.
I swapped the coilpacks and replaced al lthe plugs, i guess next is to do the injector, I'll swap first then maybe by a set...
Jett
Old 11-29-2012, 06:25 AM   #5 (permalink)
Senior TN Member
leakyseals's Avatar
Gameroom cash: $525000
View leakyseals's Photo Gallery
Worked on several mis-fire CEL's recently. Almost all were dirty injectors. My guess is the change in gas blend to winter may be exposing that. I've had good luck cleaning the injectors in place with a heavy dose of fuel system cleaners with the additive PEA. Then one bottle per OCI after as maintenance.
02 Camry XLE 2AZ-FE 290k M1 HM 5w30 10k OCI
08 Pontiac GP 3800 Series III 95k M1 0w40 10k OCI
leakyseals is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 07:11 AM   #6 (permalink)
I'll try the injector cleaner however I was considering taking them out and having them sent to a diesel injection service shop for cleaning what you think about that?
Jett
Old 11-29-2012, 10:37 AM   #7 (permalink)
Senior TN Member
leakyseals's Avatar
Sure, if you want to. After that just use PEA cleaners to keep them clean.
The Following User Says Thank You to leakyseals For This Useful Post:
Jettfixr (12-10-2012)
Old 12-10-2012, 11:13 PM   #8 (permalink)
USA
So i got 4 replacement injectors from Rock Auto the correct ones for my manufacture date, and slapped them in, well, not so good, got misfire codes for all 4 cylinders now, ok, fine. I drop my injectors in my ultrasonic cleaner that i use for aircraft fuel injectors, let them go for an hour, put them back, the drivability issues and start off issues gone but i am still getting a 0301 code. HMMM....i'm sending Rock Auto back the set they sent me, next thing is maybe the idler pulley could be shaking and causing a code? I'm stumped....
Jett
Old 12-11-2012, 01:03 PM   #9 (permalink)
Gearhead
Gameroom cash: $292365
Excessive cylinder deposits can cause a misfire code to pop up. If your car is one of those that consumes oil - this is a likely possibility.
Could also be a possible wiring issue. This engine is extremely sensitive to electrical noise. Any recent electrical mod/work should be double checked (HIDs, LED swaps, audio/video gear, etc.).
Double check the wiring to the injectors and igniters. Could be a loose or corroded connection causing the intermittent signal that is triggering the CEL.
A bad or weak battery can also attribute to electrical noise - makes the alternator work harder than normal. If the battery is more than 4-5 years old - then I'd start leaning to a electrical issue.
2002 Toyota Corolla S, 1.8L 1ZZ-FE VVT-i
2003 Toyota Matrix XRS, 1.8L 2ZZ-GE, VVTL-i (RIP)
2009 Toyota Matrix XRS, 2.4L 2AZ-FE VVT-i
2009 Toyota RAV4 Limited, 2.5L 2AR-FE Dual VVT-i
fishexpo101 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to fishexpo101 For This Useful Post:
Jettfixr (12-11-2012)
Old 12-11-2012, 05:41 PM   #10 (permalink)
Smile
I ran some sea foam spray through the intake ill check the grounds and clean them in the morning. The
Drive ability issues I had prior to dropping them in the ultrasonic cleaner have disappeared so at least I OT a positive result out of something :-)
Jett
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
