The Hose to Nowhere... - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 9th Gen Corolla/1st Gen Matrix (2003-2008)
9th Gen Corolla/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
Old 01-12-2013, 09:03 PM   #1 (permalink)
View novatoyota's Photo Gallery
I'm helpless when it comes to cars but I was peeking under the hood of my 06 Corolla LE and discovered there's some sort of small hose towards the back of the engine that's leaking clear fluid. Three photos...
What do you guys make of this?
novatoyota is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 09:07 PM   #2 (permalink)
Gameroom cash: $105700
View kazhuveri's Photo Gallery
The is the hose from the A/C condenser, I think.
- 2006 Corolla LE AT
kazhuveri is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to kazhuveri For This Useful Post:
novatoyota (01-12-2013)
Old 01-12-2013, 09:08 PM   #3 (permalink)
BlackOmega's Avatar
View BlackOmega's Photo Gallery
I bet it's the drain from the cowl.
Or a drain for the evaporator.
EDIT: That clear liquid is water.
2000 E55 AMG 426HP/ 474ft. lbs. torque
BlackOmega is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to BlackOmega For This Useful Post:
Old 01-12-2013, 09:16 PM   #4 (permalink)
Ok, that'd be better than the alternative, I'd imagine. Does it seem like it's going to the right place? I would think not, based on the rust it's causing...
Old 01-13-2013, 06:29 PM   #5 (permalink)
View flash2563's Photo Gallery
mine is normal is also air conditioned and has a bit of rust too ..
flash2563 is offline   Reply With Quote Quick reply to this message
Old 01-14-2013, 12:47 AM   #6 (permalink)
Dave's
Gameroom cash: $292650
View Dave's's Photo Gallery
You could probably measure the O.D. of the hose and buy a piece of hose with about the same I.D. and slide it over yours. No pressure so it would probably stay. Or a bit of rubber or silicone glue or a hose clamp might work too. That way you can direct the flow somewhere else.
Dave's is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 06:55 PM   #7 (permalink)
View jp233's Photo Gallery
Yes, that is the drain for the A/C evaporator, and it is a GOOD thing for water to drain out of there. The evaporator core creates a ton of condensation on it because it gets ice cold when the AC/defrost is running. The evap core is housed in a plastic box that is stuff under the dash/console behind the firewall, and the condensation build up has to drain out of somewhere (this is it).
This is why in the summertime, you will see cars/trucks sitting at red lights, look like they are profusely dripping something out. It's water. In particular, I've noticed Ford and Chevy trucks that create quite a puddle just sitting at one long red light. Totally normal.
If that spot was NOT leaking/draining water, then that's a bad thing mmkay? My inlaws have a 2006 Corolla that was a kids car, and while they were at college the first 2-3 years they left it in the garage and barely drove it. Over one winter, some varmints moved into the evap core box and made a nice home. (and you do know that vermin crap where they sleep and eat, right?) They filled the box with stuffing and crud and crap, and gummed up the drain hose. Then once summer came and they started running the AC, the water couldn't drain anywhere and it started leaking onto the carpet in the car. It STUNK horribly. And, was a real bear to get apart, clean out, and get back together. I still don't think the kid got all the gunk out of there.
OH, and I just looked at our 2008 Corolla, and yeah, we have rust in that same spot (which is a hose bracket for the power steering rack). Grrrrrr.... I'll hit that spot with some sand paper one day and a shot of Rustoleum. That's not a good spot to drain it if that bracket isn't stainless or coated otherwise to prevent rust.
jp233 is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to jp233 For This Useful Post:
MD1032 (01-15-2013), novatoyota (01-16-2013)
Old 01-16-2013, 08:29 PM   #8 (permalink)
Thanks so much!
Old 01-16-2013, 09:42 PM   #9 (permalink)
04 Corolla CE manual
Gameroom cash: $612604
View invader's Photo Gallery
All that water condensed at the cold evaporator is moisture removed from admitted (or recirculated) air, allowing for reduced humidity beside available cooler air... With A/C off, A/C still cycles on and off when vent selector is clockwise of 'floor' setting, at 'floor/windsheld' and at 'windshield' settings for efficient windshield and windows defogging/defrosting.
invader is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
