corolla 2005 headlights always on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2006, 01:57 PM   #1 (permalink)
View gbp007's Photo Gallery
Hi i just bough a 2005 corolla and when im driving or im parked with the engine running the headlights are always on even though i didnt turn them on ..Even at day the healights are also on and there is no way to turn them oof when im driving..Is this how corolla's are suppose to be and is there any way i could fix this ? Please help ?
gbp007 is offline   Reply With Quote
Old 07-26-2006, 02:21 PM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Those are your DRL's its a safety feature...I don't think their at full brightness during the day...If you look on your dash on the left side under your window it has a round black sensor that senses darkness and turns on your lights to full power at night, I haven't turned my lights on manually since I bought my car I like that feature...Anyway I heard that you can pull the E-brake up a little and that will shut them off, I never tried it...As for removing the DRL feature there has been many posts here on how to do that, just go to the top right of the corolla forum and where it says "search forum" type in DRL or the question you want to ask...good luck...
~Radd
Raddman is offline   Reply With Quote
Old 07-26-2006, 08:21 PM   #3 (permalink)
<3 lift
View XRS yo's Photo Gallery
^^ what he said. DRL's.
They are at ~60% of full power during the day, and will automagically turn on at night (although it may take a few hundred feet of driving if you turn your car on in the dark.)
There is a simple disable for the automagic/daytime lights ... head over the 9thgen and search around over there. Requires crawling under the steering column and clipping a wire, then jumping it to another wire. Took me like 10 mins, max.
The ebrake method does work. Basically, if you pull the ebrake up to the first click, it will show "BRAKE" on your gauge cluster. The DRLs are activated by the ebrake being off and the car being in motion. If you leave it on the first click, the brake light shows, but the brake is not ACTUALLY physically engaged -- the car just thinks it is. So the DRL's will not come on. I dont know how the effects the auto lights though. (The ebrake doesnt physically engage until the 3rd or 4th click)
2005 Toyota Corolla XRS / GainesvilleRacing.com
XRS yo is offline   Reply With Quote
Old 07-28-2006, 02:40 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
gbp007, I'm assuming you haven't bought a new car in a LONG time.
Daytime Running Lights is a feature that became government "required" on all cars built on or after 1990 for the north american markets.
Old 07-28-2006, 08:40 PM   #5 (permalink)
I Like Traffic Lights !!!
05_Echo's Avatar
View 05_Echo's Photo Gallery
Canada
Nope just us Canadians have them as mandatory equipment. It is a great feature because you can see headlights coming at you in the daytime alot easier than a car with out them on. They proved it cut down on accidents up here.
My Cars, 2006 Corolla CE, 2003 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is offline   Reply With Quote
Old 07-29-2006, 12:43 AM   #6 (permalink)
2005 TRD Corolla
thms05corolla's Avatar
View thms05corolla's Photo Gallery
They're called daytime running lights, and every new Corolla has them, including my '05 LE. You can disable it with minor wiring under the dash (I did it to mine), but then it turns off your automatic headlights, IMO I would just leave them in unless you get HID.
2005 TRD Corolla LE
1.8L 1ZZ-FE
ZZE130
thms05corolla is offline   Reply With Quote
Old 07-29-2006, 01:02 AM   #7 (permalink)
View Maxpayne124's Photo Gallery
im not sure about the newer corollas but my 95 has 2 different bulbs for lights, 1 for lowbeam and 1 for highbeam and Daytime Running Lights. all u have to do if you have this setup is disconnect your high beam bulbs if you can live without them.
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 07-30-2006, 02:10 AM   #8 (permalink)
View toyomoho's Photo Gallery
Running lights have been proven to enhance a cars visibility and reduce “accidents”. The electrical system should be designed to handle the load.
Old 07-30-2006, 04:05 AM   #9 (permalink)
9THGEN GURU
View jcturbo's Photo Gallery
the electrical system can handle it, but the bulbs burn out fast!!! I dropped my first set at 6 months.
No Wiring is involved to disable them, simply cut the red wire with the white stripe in pin 12 on the connector to the DRL control box located directly up from the brake pedal, it;s the wire on the bottom right looking at it from the wire side it's next to the TWO larger wires. A little electrical tape and all is well
jcturbo is offline   Reply With Quote
Old 07-30-2006, 08:04 AM   #10 (permalink)
Registered User
Raddman's Avatar
USA
jcturbo]the electrical system can handle it, but the bulbs burn out fast!!! I dropped my first set at 6 months.
Your right, if your using expensive bulbs it can be costly, my Silverstars never last more then a year.....Even at running 60% power in daylight their always on!
~Radd
Old 07-30-2006, 09:59 AM   #11 (permalink)
9THGEN GURU
Old 10-05-2007, 06:26 PM   #12 (permalink)
View murone's Photo Gallery
My wire on pin #12 is red/black on 2005 Corolla CE. Is this still the correct wire to remove to disable the DRL?
Thanks
murone is offline   Reply With Quote
Old 10-05-2007, 08:58 PM   #13 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Holy thread revival batman
Have you got a wiring diagram at all?
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 10-05-2007, 10:27 PM   #14 (permalink)
Not for a 2005 Corolla. I've got the 2000 Toyota TSB that says the pin to disconnect on the Corolla is #23, and there aren't 23 pins on my connector. I also have diagrams for the Matrix and Vibe, but they don't match what I'm looking at under the steering wheel. It seems that the 2005 Corolla may be a little different. Most of the stuff that I'm reading says pin #12, but wire on #12 is red/black instead of red/white. I would assume that the color coding is consistent and done for a reason.
Thanks
2005 Corolla - can't remote start tdok 9th Generation (2003-2008) 9 06-16-2007 04:30 AM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 01:26 PM
2006 or 2005 corolla iffireno Archived Corolla threads 4 07-13-2005 05:53 PM
corolla s 2004 or 2005 wangara Archived Corolla threads 1 06-08-2004 03:32 AM
