2003 Corolla LE (a few questions)
My g/f just picked up a 03 Corolla LE Auto with 60,000miles on it.
She bought it off a local used car lot, the car came with NO maintenance records. I told her to contact the use car guy and get the history atleast from the dealership where it was bought new from if there's anything.
Anyways, I plan to give the car a good look over and tune up. I don't know much about these cars, as I'm a Dodge Truck owner myself and I do my own work.
Is there any problem areas I should look at or be concerned of??
-I plan on changing the spark plugs, what is recommended?? I like to stick with NGK if possible, they make great plugs.
-Coolant change, have any of you guys switch over from the orange stuff to the green stuff??
-Steering fluid need replacing??
-I'll be flushing the brake fluid and inspecting the rest of the brake system.
-Tranny will also get a flushing.
-Air filter and pcv valve will also be changed
Anything else you guys can add or I over looked would be great.
Thanks,
Anthony
