2007 Corolla hard starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2007, 08:58 AM   #1 (permalink)
View wdoa's Photo Gallery
Purchased a brand new 2007 Corolla about a month ago. For the last several weeks I've noticed that the car needs a few more seconds (10 seconds or so) of cranking to start than other cars I've owned. Since this is my first Toyota I thought maybe it was just a difference between cars and not a big deal. Now I'm not so sure, as this morning when I went to start the car after it had been sitting for about 12 hours I felt I was almost close to needing a tow. I tried starting the car, cranked the engine for about 20 seconds, but the car didn't start. Tried again, this time for about 30 seconds, still no joy. Finally on the third time it did catch after about 15 seconds, but sputtered for a few seconds as it started. It was cold outside (10 F), but I've not had this problem with other cars I've owned, also yesterday morning was colder and the Corolla had been sitting longer and I didn't have the problem.
I called the service department of the dealership and they blamed it on the cold and said they didn't think it was anything out of the ordinary.
Any thoughts? Thanks
-Mike
wdoa is offline   Reply With Quote
Old 02-16-2007, 10:46 AM   #2 (permalink)
07 Corolla
Jonny Steele's Avatar
View Jonny Steele's Photo Gallery
Dude, i have an 07 corolla, the longest i have ever had to start is maybe 3 or 4 secs, you might need to take it back to dealer
Jonny Steele is offline   Reply With Quote
Old 02-16-2007, 11:06 AM   #3 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $443101
View falnfenix's Photo Gallery
correct. it's under warranty, take it back to them.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 01-09-2008, 11:22 AM   #4 (permalink)
Location: St. John's, Newfoundland and Labrador, Canada
View tkocurko's Photo Gallery
-Mike
So, did you ever get a solution to the problem of your '07 Corolla needing excessive cranking to start after sitting outside in the cold over night? We've got exactly the same problem, but the local dealership had no idea what's causing it, although their technician personally witnessed the symptom. They "took a snapshot" (of the ECM, I suppose) and sent it off to the mainland (we're on the island of Newfoundland), but the mainland came back and said that they couldn't spot anything causing the problem, either. I was hoping that you might have had better luck. At the moment, the local dealership is giving us a loaner, while our '07 Corolla waits on their lot for a cold night.
tkocurko is offline   Reply With Quote
Old 02-05-2008, 06:22 PM   #5 (permalink)
View soldsoul4foos's Photo Gallery
Maybe a shitty fuel filter...from bad gas? I had this problem on my 97' suburban recently. Ended up being a plugged fuel filter, and after a little time, the extended cranking deteriorated the spark plugs. New filter, new plugs, good 2 go. Just a thought.
Late,
Bill
soldsoul4foos is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 05:20 AM
2007 Corolla S idle RPM's sprtzfrk Archived Corolla threads 5 01-25-2007 05:38 PM
99 Corolla starting issue atoyotchick Archived Corolla threads 5 01-29-2006 09:39 PM
1991 Corolla has Occassional Problems Starting PoopEater Archived Corolla threads 5 01-08-2006 07:22 PM
car has hard time starting 98 corolla hasher General Discussion 8 02-09-2005 06:15 AM
