Start Up Cheat Code (Bypass Key Code) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 09:01 PM   #1 (permalink)
View JustPassinThre's Photo Gallery
Does anyone know the Toyota Corolla (05) start up cheat code where you can start up the car using a spare key without the security transponder chip in it like the Honda bypass code where you use a series of press and pulls of the emergency brake with a few rotations of the ignition key turns between the on and start positions to start the car? (some also use on and off positions of the radio)
It's kind of like using the secret codes to reveal DVD Easter Eggs or Video Game Cheats.
On further checking using a blank Toyota transponder key Toyota uses a master (black head) and sub master key (grey head) system, similar to their mechanical valet key system. The valet/sub master will operate door and ignition locks and start the vehicle but cannot be used to introduce the new key to the vehicle. The master key is used in conjunction with a series of ignition on/off cycles and opening and closing of the door to introduce new keys. (Board Author: Phi FYI- How Transponder Keys Work )
My interest is in using a standard spare key without a tranponder chip (the spare key in my wallet should I lose the large head Toyota transponder key)
JustPassinThre is offline   Reply With Quote
Old 01-02-2009, 09:32 PM   #2 (permalink)
View c230K's Photo Gallery
why not just keep a standard transponder key near your ignition switch so you can use a metal key from Lowes or Home Depot?
c230K is offline   Reply With Quote
Old 01-02-2009, 09:38 PM   #3 (permalink)
View toyomoho's Photo Gallery
Never heard of this type of bypass on Toyota's.
Suggest you make a duplicate transponder master key and keep in a safe location or use valet keys. If you lose the master key its can be VERY expensive to replace.
Old 01-03-2009, 05:44 PM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $383212
View Jeff Lange's Photo Gallery
It was more expensive on older Toyotas. The newer models aren't very bad, you can completely reset the system and program a new master key. Toyota would have to do it though.
Older Toyota immobilizers required replacement of the ECU.
(9th Gen Corollas are the newer type).
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
FYI- How Transponder Keys Work Phi Audio, Video, and Security - Tech 3 01-02-2009 09:44 PM
Toyota Engine code vivian General Discussion 22 12-27-2008 02:16 AM
'85 rolla no start powerslide713 Older Generations (1969-1987) 10 04-08-2008 11:07 PM
1992 Cilica will not start Gil Celica Forum 6 05-19-2005 11:37 AM
turn key twice to start car. jamesmetairie Archived Corolla threads 15 06-10-2004 05:01 AM
