Originally Posted by tigrpal
It is behind the glove box. Open the glove box. You may be able to reach it with your fingers or else unscrew the rod that keeps the glove box from opening too far and then squeeze the sides to open it past the tabs. The filter is right there.
It's easier to get at by removing your glove compartment door, just push in the two side tabs....
Note, replace it yourself, it's simple(a ten minute job) you can buy a filter for $20, your dealer will charge you $50+ for doing it!
