I own a 2006 Toyota Corolla CE (Manual transmission) with about 24,000 miles on it. This car has been absolutely perfect...until a couple of days ago, when I discovered that the air conditioning no longer worked. You know how your car idles a bit higher and loses some power when the A/C is running? This wasn't happening. The compressor failed to start up.
So, the next day, I took over to one of three Toyota dealerships in my city. The service technician assured me that it was probably an electrical relay or, at worst, the air conditioning clutch. I received a call a few hours later. As it turns out, a rock punctured the condenser, causing all the refrigerant to leak out. Since this isn't considered a manufacturing defect, it's not covered by the warranty. $500 for a new condenser.
I opted not to have it replaced. I quickly called Toyota Motor Corp. and complained. The customer service rep dispatched a file number to the dealership and told me that they (Toyota Motor Corp.) would see what they could do. Sure enough, the dealership concluded that since it isn't a manufacturing defect, it won't be covered by the factory warranty. Upon calling Toyota Motor Corp. for the second time, they concurred. I was given the analogy, "This would be like running over a nail, getting a flat tire, and expecting the tire manufacturer to pay for it." Yes. It's *exactly* like that.
This has to be a design flaw. Plain and simple. 99.9% of my driving is done on paved roads. A Google search revealed that the only car that seems to have this problem are the previous generation Honda Accords. Which brings me to my questions:
1. Even if the system were to have no refrigerant in it, shouldn't the compressor still be kicking on? Any possibility that it could still be an electrical problem? Any possibility that the dealership is trying to screw me over? (Hah. I should know the answer to that one already.)
2. What should I do at this point? I'll be writing a letter to Toyota Motor Corp., as I've heard of stories where automakers will pay for unusual repairs if you complain enough.
3. Even if the condenser were to get replaced, what's to stop this from happening again? Do I really have to worry about small rocks damaging the A/C system in my car from now on?
I apologize for the long post. Thanks to anybody that has taken the time to read this.
