Disable DRL's on 2007 Corolla S class - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2007, 01:58 PM   #1 (permalink)
View john54's Photo Gallery
Hey all,
I haven't seen anyone post any thing specific on 2007 models. The closest thing I found was a TSB but it only mentioned models up to 2000 model. Does anyone know or have a official word on how to disable the drls on 2007 models?
john54 is offline   Reply With Quote
Old 04-11-2007, 02:57 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
i would post a link but it will get starred... just go to 9th gen corolla dot com (without the sopaces) and search for DRL DISABLE.. u will get a step by step on it
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-12-2007, 05:18 PM   #3 (permalink)
View polo708's Photo Gallery
yeah, what daniel said... but underneath the steering wheel there is a "box with wires". cut the yellow wire and ground the end not connected to the box. Above site has pics^^
2004 Supercharged Corolla S
polo708 is offline   Reply With Quote
Old 12-09-2007, 10:18 AM   #4 (permalink)
View ortizre's Photo Gallery
DRL disable
I tried the cutting of the yellow wire going to the box and grounded it then I turned on the car and the DRL still turned on.
ortizre is offline   Reply With Quote
Old 12-09-2007, 10:42 AM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $467667
Did you ground the end coming out of the DRL box? Did your battery light come on?
mikered30 is offline   Reply With Quote
Old 12-09-2007, 05:08 PM   #6 (permalink)
Sensible's Avatar
View Sensible's Photo Gallery
Just curious.... but why do you want to disable the day time running lights? Is it for some special reason or look??? Sorry, just wanted to the know the reasoning behind it.
Sensible is offline   Reply With Quote
Old 12-09-2007, 05:16 PM   #7 (permalink)
uʍop-ǝpısdn
rollatuner110's Avatar
View rollatuner110's Photo Gallery
You will need to disable them if you have HIDs. Plus they reduce bulb life, have a parasitic current draw from the battery, and could distract other drivers on the road. They don't necessarily make the car any safer. It's just something unnecessary.
rollatuner110 is offline   Reply With Quote
Old 12-09-2007, 05:43 PM   #8 (permalink)
Sensible's Avatar
I can understand the need to disable for HID's but in my opinion I don't think DRL's are distracting to other drivers if your lights are aimed properly. Thay should be on the road and not in other peoples eyes. Just my opinion though. This is my first Corolla so I don't know about the parasitic loss and bulb life .Thanks for the info though.
Old 12-10-2007, 07:44 PM   #9 (permalink)
Deep south Texas
No, I grounded the end not attached to the DRL box and I didn't see the battery light on.
Old 12-10-2007, 08:14 PM   #10 (permalink)
mikered30's Avatar
Ground the end that comes out of the DRL box
Old 12-10-2007, 08:20 PM   #11 (permalink)
Raging Raven
View TenZen's Photo Gallery
Parasitic loss and bulb life are on all cars. Bulb life is more on cars with DRL's. The ECM is always on even when the car is off, but't not a whole lot of voltage it uses.
2005 Dodge Neon SRT-4
Originally Posted by FinalGear View Post
gosh...those honda guys....as soon as they put the intake in their Civics...it goes faster than any Mustang, Evo, and Sti....
TenZen is offline   Reply With Quote
Old 12-12-2007, 02:07 PM   #12 (permalink)
I was finally able to get to the car and ground the yellow wire that is coming out of the DRL box. Lo and behold you were correct I tested my headlamps and everything operated as I wanted... Thank You very much for your assisstance...
Old 12-12-2007, 02:52 PM   #13 (permalink)
mikered30's Avatar
No problem.
Old 12-12-2007, 05:13 PM   #14 (permalink)
uʍop-ǝpısdn
haha Corolla S class. That's a first.
Old 12-19-2007, 02:12 PM   #15 (permalink)
Glockaholic...
kn38ms's Avatar
View kn38ms's Photo Gallery
Better drivers make roads safer, not DRL's.
DRL's are a PITA. What if you want to idle at night without having your lights on?
Hunters and sportsman can benefit from not having DRL's giving away your location.
I know when to turn on and off my headlights.
Its just another example of Government dumbing down society.
kn38ms is offline   Reply With Quote
Buying a 2007 Corolla frost_ryder Archived Corolla threads 13 08-05-2007 05:44 PM
Anyone know how to Disable alarm on 2007 Camry…? mrlevis 5th & 6th Generation (2002-2006 & 2007-2011) 1 06-25-2006 10:33 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
disabling 03 corolla drl's lumsifu Archived Corolla threads 3 04-20-2004 09:27 AM
