oil drain plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2007, 11:21 PM   #1 (permalink)
View h3nG's Photo Gallery
oil drain plug
n00b question -
where is the oil drain plug on the 05 corolla located? i found a hex screw in the center of this black square-ish (about 1'x1') thing at the bottom center under the engine. pardon my description...lol. where can i find a picture diagram?
just wanted to confirm before i unscrew the wrong screw, lol.
thanks in advance!
h3nG is offline   Reply With Quote
Old 04-17-2007, 11:36 PM   #2 (permalink)
View tech8's Photo Gallery
Your owner's manual will show a picture. I believe it is a 14 mm bolt. Use a box end wrench or socket to loosen it. Then remove by hand without tool. When oil is drained, place new crush washer on oil drain bolt, and finger tighten first (to prevent cross-threading), then tighten with wrench or socket.
The oil filter may need a oil filter cap wrench to remove, as it usually is fairly tight. Apply a light coat of clean oil to the oil filter o-ring gasket, and only hand tighten. No need to use a tool to tighten the filter.
tech8 is offline   Reply With Quote
Old 04-17-2007, 11:56 PM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Located in back of your oil pan!
Raddman is offline   Reply With Quote
Old 04-18-2007, 12:15 AM   #4 (permalink)
thanks guys!
For thoes that bought the Fumoto drain plug? timpearson26 2nd Generation (2005+) 29 12-11-2006 03:29 PM
anyone else using a winged oil drain plug ? nobitanobi 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-20-2006 11:57 PM
Magnetic Oil Drain Plug? 93ToyCorolla Archived Corolla threads 6 07-12-2006 11:07 AM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 05:32 AM
Socket size of oil pan drain plug Kooter Camry & Solara Lounge 4 10-17-2003 09:14 PM
