Replacing factory tires on my '05 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2007, 01:37 PM   #1 (permalink)
View Guido's Photo Gallery
Factory is 185/65-15, I'd like to go up to 195/65, or must I use 195/60? There is much more selection with the 65 aspect ratio, but I'm worried about interference.
Thanks.
Guido is offline   Reply With Quote
Old 06-28-2007, 08:45 PM   #2 (permalink)
View AVANT's Photo Gallery
Stick with the 185/65 range. Going with a 195/65 isn't impossible as I'm sure it'll physically fit, and there's "probably" enough clearance to not rub. But I would strongly recommend going with a 60 aspect ratio if you want 195. I'm not a fan of making the car taller and throwing the speedo off.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 06-29-2007, 09:44 AM   #3 (permalink)
I just found out the LE & S models come from factory with 195/65 15. So assuming they use the same rim offset, interference shouldn't be a problem. However they probably do have a recalibrated speedo - good point.
Old 06-29-2007, 12:37 PM   #4 (permalink)
BANNED
View w203's Photo Gallery
http://www.corollaforums.us/forum/viewtopic.php?t=183
w203 is offline   Reply With Quote
Tires for corolla?? Chris Corolla S Archived Corolla threads 3 10-02-2007 08:15 PM
Toyota Corolla LE 1998 Tires vseth Archived Corolla threads 3 05-19-2005 06:22 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
TIRES FOR COROLLA Chris Corolla S Archived Corolla threads 7 08-24-2002 02:48 AM
