'03 Corolla A/C problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2007, 03:47 PM   #1 (permalink)
View adamsjef's Photo Gallery
My 2003 corolla A/C has been working intermittently the past few days. I determined that the clutch wasn't engaging. I played with the MG CLT relay, and it kicked in, but I'm not sure if that was just dumb luck. What are some of the different things that can prevent the relay from engaging the clutch? I put some refridgerant in the other day, but I still haven't taken any pressure readings.(I'm not sure where to take them, and what pressure is normal.) When the A/C is engaged it's nice and cold. I just would like to try and isolate the problem a little more before spending too much money chasing the problem around. A new relay should only be $60, but I'm not 100% sure that's it.
I'm not sure how to jump the relay, so if someone could explain it might help.
Any suggestions would be greatly appreciated.
Jeff
adamsjef is offline   Reply With Quote
Old 06-29-2007, 04:01 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
thats something you absolutely shouldnt do.
Some things that prevent the magnetic clutch from engaging:
1)Contact failure
2)too little pressure
3)too high pressure
4)wiring problem
5)Magnetic clutch relay faulty.
Old 06-30-2007, 06:50 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
go to http://acsource.com/ forums for best help with a/c:
http://www.acsource.net/acforum/
and ask your questions there..
retiredat44 is offline   Reply With Quote
Old 11-21-2007, 07:00 PM   #4 (permalink)
View Vladi's Photo Gallery
It's probably too late, but I have the same problem, you can use the relay from the horn, it's almost the same(if not the same). I have switched mine with the MG CLT Relay and now the A/C is working fine.I have no horn for now, but I rather have the A/C.
Vladi is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 12:14 PM
'99 Corolla A/C light blinking - car shuts itself off redskins13 Archived Corolla threads 15 01-25-2006 02:33 PM
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 05:02 PM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
