2003-04 corolla keyless entry programing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2003, 09:28 PM   #1 (permalink)
View crayola's Photo Gallery
does anyone know how to program the key fob on the new Corolla keyless entry???
crayola is offline   Reply With Quote
Old 08-13-2003, 05:19 PM   #2 (permalink)
View denyed's Photo Gallery
I am looking for the same thing for my 2002!! My current one works, but the back panel broke in half, and toyota wants to charge me $60CAD! for a new one. Yikes! I can easily get one online, if I only knew how to program it. I am wondering what system is in the 2002-2003 corolla, i've been reading about RS3000 and RS3200... help....?? please
denyed is offline   Reply With Quote
Old 03-22-2004, 01:00 PM   #3 (permalink)
View FriedMango's Photo Gallery
Programming Instructions for Corolla, Avalon, Camry, Matrix, Echo, Highlander, others
Programming OEM Wirless Door Lock Remote Transmitters (taken from Toyota Technical Service bulletin Dated 7/19/02)-Applies to 2000-2003 Celica, 2001-2003 Echo, Highlander, Prius and RAV4, 2002-2003 Camry and Avalon, 2003 Corolla and Matrix.
1)Driver’s door open and unlocked.
2)Insert and remove (do not turn) key from ignition two times (within 5 seconds).
3)Close and open driver’s door TWICE (within 40 seconds).
4)Insert key in ignition (do not turn) and remove.
5)Close the door.
6)Turn the ignition switch from “Lock” to “ON” and back to “Lock” at about one second intervals to select the desired mode:
-1 time for ADD mode
-2 times for REWRITE mode
-3 times for CONFIRMATION mode
-5 times for PROHIBITION mode
To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a number of time corresponding to your key cycles in earlier in this step.
7)For ADD or REWRITE modes, within 40 seconds of Door Lock confirmation
a)press both Lock and Unlock buttons on transmitter simultaneously for about 1.5 seconds.
b)within 3 seconds of step A, press only the Lock button for 1 second.
c)If the transmitter has been successfully programmed, the power locks will cycle “lock” to “unlock” ONCE. If there is a problem, the locks will cycle TWICE. If this occurs, verify you have the correct transmitter, and repeat the above procedure.
d)If multiple remotes are to be repropgrammed, Repeat steps A-C.
FriedMango is offline   Reply With Quote
Old 11-16-2008, 04:51 PM   #4 (permalink)
View steadfast7893's Photo Gallery
Smile
5)Close the door.
steadfast7893 is offline   Reply With Quote
Old 11-16-2008, 04:54 PM   #5 (permalink)
Will this work on a 2001
I think i have the right remote but wrong instructions with it.
Dose any one have the2001 instructions
frustrated in Ontario
Old 11-16-2008, 04:58 PM   #6 (permalink)
Dose any one have the 2001 Corolla instructions?
I've tried it four times.
Old 11-20-2008, 12:03 AM   #7 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada
Keyless Entry Programming
1. REGISTRATION OF RECOGNITION CODE HINT:
o The add mode is used to retain the already registered codes while registering a new recognition code. This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously registered code will be correspondingly erased in order, starting from the first registered code.
o The rewrite mode is used to erase all the previously registered codes and register only new recognition codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
o The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function. Use this mode when the transmitter is lost.
o The confirmation mode is to confirm how many recognition codes have already been registered before an additional registration of a recognition code.
o All the following registration procedures must be performed in order continuously.
1. The vehicle should be in the following conditions.
1. No key is in the ignition key cylinder.
2. Driver's door is opened (the other doors are closed).
3. Driver's door is unlocked.
2. Perform the following operations to select the desired mode.
1. Insert and remove the key from the ignition switch twice within 5 seconds .
2. After the above operations, close and open the driver door twice within 40 seconds . Then insert the key into the ignition key cylinder and remove it.
3. After the above operations, close and open the driver door twice within 40 seconds . Then insert the key into the ignition key cylinder and close the door.
4. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second intervals 1 to 5 times to select a mode (see the table). Then remove the key from the ignition key cylinder. NOTE: If the number of the ON-LOCK operations of the ignition switch is 0, 4 or 6 or more, there will be no response (power door lock and unlock operation) to inform which mode has been selected.
5. After selecting a mode, the integration relay automatically performs the power door LOCK-UNLOCK operation within 3 seconds to inform the selected mode (see the table).
HINT:
* In confirmation mode, the LOCK-UNLOCK operation will occur once for each recognition code that has been registered. For example, if 2 recognition codes have been registered, the LOCK-UNLOCK operation will occur 2 times.
* In confirmation mode, if no recognition codes have been registered, the LOCK-UNLOCK operation will occur 5 times.
* In confirmation mode and prohibition mode, once a LOCK-UNLOCK operation response has occurred, the registration procedure will end.
3. Register the new recognition codes (Add mode or Rewrite mode):
1. Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK switches on the transmitter simultaneously for 1.0 to 1.5 seconds .Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds .
2. Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
3. If multiple transmitters need to be registered, repeat step (1) within 40 seconds after the previous registration. HINT:
o 4 recognition codes can be registered at once.
o If even one of the following conditions is satisfied, the registration mode will finish.
o 40 seconds have elapsed since the most recent transmitter registration.
o Any of the doors is opened.
o The key plate is inserted in the ignition key cylinder.
o 4 recognition codes are registered at once.
Here are the instructions for the 2003 Toyota Corolla Model.
1. Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
2. Perform these steps within 5 seconds
a. Insert the key into the ignition (don’t turn it) Pull key out
b. Insert the key into the ignition (don’t turn it) Pull key out
3. Perform these steps within 40 seconds
a. Close, then open the drivers door.
b. Close, then open the drivers door.
c. Insert the key into the ignition (don’t turn it) and pull it out.
4. Perform these steps within 40 seconds
c. Insert the key into the ignition and leave in the ignition.
d. Close the drivers door
Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds
a. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
7. Open drivers door
2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 10-18-2009, 03:02 AM   #8 (permalink)
View aodeng's Photo Gallery
this post is great! I got the detailed guide to program the remote.
Thanks!
aodeng is offline   Reply With Quote
Old 02-21-2010, 11:49 AM   #9 (permalink)
View kingkingwolf's Photo Gallery
this post is very nice. THanks.
kingkingwolf is offline   Reply With Quote
