Is the key in the trunk lid or body? Which ever location remove the trunk liner behind the lock to access.
If the key is not turning, the lock may be worn out and need to be replaced.
As a temp fix spray lock graphite into the lock, a common product at hardware stores.
Have you tried using another key, a worn key can cause problems.
The lock should be easy enough to remove, the dealer should have a replacement it may not be the same key.
If the key is turning the issue is in the locking mechanism. This is typically on the opposite area of the lock latch and is usually held in by a couple of bolts.
