? on the Gearbox for a 2003 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2008, 01:11 PM   #1 (permalink)
View nfrockmini's Photo Gallery
Hi All,
It appears that my poor little Corolla S is going to need a replacement gearbox. What gearbox should I be looking for? And will the gearbox from any previous or subsequent years fit my car?
Thanks for your advice!
Brian
nfrockmini is offline   Reply With Quote
Old 12-04-2008, 04:53 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Originally Posted by nfrockmini View Post
Hi All,
Brian
Transmission code is C59, check out page 135 of http://www.carlibrary.ru/toyota/serv...ures_specs.pdf
It appears that some minor work was done between the years. The first gen Matrix should have the same tranny, I would assume the Vibe would have the same tranny too. Did your tranny take a dump?
mikered30 is online now   Reply With Quote
Old 12-05-2008, 09:26 AM   #3 (permalink)
Not yet, but I sense the impending doom. I have had the car to two shops and some bearing somewhere in there is getting ready to fail. I get a lot of noise from the gearbox when the car is moving. It runs fine and shifts normally. But there is some mechanical noise coming from the gearbox. The puzzler for me is that the noise stops when I put the clutch in and the car is moving. So, question...If there was a problem in the gearbox, wouldn't the noise continue if the car was moving regardless of clutch position? The gears would still be moving, right? So is it possible the gearbox is fine and the clutch/pressure plate is the culprit?
I'd sure appreciate any advise.
Thanks
Old 12-05-2008, 12:53 PM   #4 (permalink)
View ryan_t888's Photo Gallery
With the car moving, if you push the clutch in and it is still in gear, the meshed gears in the tranny will still be turning. If you toss it in neutral only the output set of gears will be spinning. The input gears should be quite close to stopped.
If you push in the clutch with the car still moving when it made the noise and the noise goes away, that to me would indicate a clutch issue.
Ryan
ryan_t888 is offline   Reply With Quote
Old 12-09-2008, 09:57 AM   #5 (permalink)
I Like Traffic Lights !!!
05_Echo's Avatar
View 05_Echo's Photo Gallery
Canada
It's not a clutch issue at all it is a bearing in your tranny and I went through this crap last summer with my 06. I went and bought a used tranny from the wreckers from a 07 with only 5400 kms (3100 miles) and had that installed. I kept my old one to have it rebuilt when this one goes and from what I understand it will.
03 to 08 Corolla and Matrix/Vibe will all work in your car.
My Cars, 2006 Corolla CE, 2003 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is offline   Reply With Quote
