2007 CE No Windshield Washer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2008, 02:44 PM   #1 (permalink)
View hinmo's Photo Gallery
I've tried the obvious:
It was empty.
I filled it.
didn't work
I pulled off the Y connection and sucked fluid up from tank. Getting fluid to the Y fine (tastes great...not!).
I don't hear the pump coming on. Does anyone know which fuse it is? The owners manual does not specify.
any help appreciated.
hinmo is offline   Reply With Quote
Old 12-20-2008, 10:10 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
It was empty.
I filled it.
didn't work
Check number 30, it is 15 amp.
http://i16.photobucket.com/albums/b4...elocations.jpg
If the fuse is ok, you will likely need a new pump motor.
mikered30 is online now   Reply With Quote
Old 12-21-2008, 03:01 AM   #3 (permalink)
good stuff - I'll check. Thx
Old 12-21-2008, 09:09 AM   #4 (permalink)
nope, not the fuse. Guess its the pump...great.
Anybody know if the pumps under warranty?
07, with 28K miles?
thx
Old 12-21-2008, 11:27 AM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
07, with 28K miles?
thx
My pump went, Toyota really buried it, I got to it by taking the passenger wheel surround liner off, bought a universal pump kit for around $15, wasn't a hard install and works fine now, the old pump was rusted from the inside out splitting the unit and started making noise before it died! I didn't have to take the whole surround off just the front and bent it back!
36K-36 months, should be under warranty, mine wasn't!
Raddman is offline   Reply With Quote
Old 12-21-2008, 11:51 AM   #6 (permalink)
mikered30's Avatar
07, with 28K miles?
thx
Since your washer tank is not frozen, which could have damaged the pump, I don't see how toyota could deny the pump under the bumper to bumper warranty. A new pump is $50. I would take it in and see what they say. Maybe you could check the connection to the pump to see if it is just loose?
Old 12-22-2008, 07:07 AM   #7 (permalink)
Even thos its 17 degrees out, I went out and think I found a hint: the fog light body spacer is been knocked out, leaving an open gap to the w/washer tank/pump. I'm sure it was pelted with direct ice/snow from the road. I betcha either the wiring is disconnected or the pump ruined from stuff hitting it.
Radd - did you get the universal pump from an autoparts store? Autozone?
I guess I will need a body panel space too.
I'm guessing Toyota will not cover the pump claiming its due to a road "accident"
Old 12-22-2008, 04:11 PM   #8 (permalink)
Registered User
Raddman's Avatar
USA
I got it at a Carquest in Jacksonville Florida last fall, Autozone wanted like twice the amount! It wouldn't hurt to see if Toyota would replace it, all you'll waste is a little time, I wore out my black outer door/weather seal by getting in and out of my car rubbing on it causing it to wear and split, Toyota replaced it free under warranty! I think the seal cost $80
