03 poor mpg,s= - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2008, 05:45 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
03 poor mpg,s=
2003 corolla with about 90,000 miles. getting 21mpg in city with a/c on. what would you check first maf and iat?? what is iat? idle air??
6&8.
jamesmetairie is offline   Reply With Quote
Old 12-22-2008, 06:48 PM   #2 (permalink)
View rsirois's Photo Gallery
21 MPG isn't too bad if it's in a dense city with speeds averaging under 25 with the AC running.
I'd check my air filter and tire pressures first. After that I'd run it on the highway for over a half hour with some fuel injector cleaner in it.
rsirois is offline   Reply With Quote
Old 12-22-2008, 06:55 PM   #3 (permalink)
View holler1's Photo Gallery
Can't answer your question directly, but yesterday I found a thread on cleaning idle air control valve (IACV), PCV and a bunch of other related areas. http://matrixowners.com/?showtopic=65513
This is for matrix but I think the engine is the same since the IACV looks identical to the 03 Corolla I am checking out for my daughter. BTW I saw your question about engine temp and my sense is that the temp gauge is not sensitive or rapid enough to pick up fan cycles. Someone also verified that the temp gauge sitting at about 8:30 on a clock face is about normal. I'm envious of your of AC in Metairie; it's about 4 F here.
91 Camry auto with 150000+ mi-best car ever
98 Tacoma ex cab 5 spd 1.7 liter with 85000 mi-new
98 Volvo V70 AWD with 140000 mi
Specialized Allez Elite
holler1 is offline   Reply With Quote
Old 12-22-2008, 07:17 PM   #4 (permalink)
a/c in winter = poor mpg,s
my wife likes to use the a/c on max(recirculation) all the time ,even in winter to keep gas fumes from entering our car. using a/c in 40 degree weather ain,t green.
6&8.
Old 12-22-2008, 08:41 PM   #5 (permalink)
00 rolla VE
View huangxin's Photo Gallery
why not just turn the air on but keep the A/C off? it would circulate the air inside the car without burning extra gas
huangxin is offline   Reply With Quote
Old 12-22-2008, 09:08 PM   #6 (permalink)
that,ll work
we just got this car recently. the old lumina had to have a/c max.
6&8.
Old 12-23-2008, 07:58 AM   #7 (permalink)
'11 Camry
View JasonA's Photo Gallery
In addition, if it's cold enough (usually around 40*F or below), the A/C won't engage anyway. The ECU locks out A/C compressor operation in moderately cold ambient temperatures under the assumption that the air is dry enough anyway at those temperatures, and the A/C won't really be effective.
JasonA is offline   Reply With Quote
