If your 07 has the same setup as my 06 Taco, there is a dot on the blade where the key is cut just under the fob. These keys can only be programmed through the OBDII port. The dot is particular. If your existing key has it, you need the programmer.
Long story short, I got a key, uncut from a locksmith for a RS. Did pretty much as you described. No luck. Went back and the guy cut the key for me. still no luck. Found another locksmith who told me about the programmer and just happened to have it. had the key, uncut in 2 mins, after a 30 min drive.
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
