05 corrolla what size speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2008, 02:18 AM   #1 (permalink)
View ethan's Photo Gallery
I have the 2005 corrolla s with the 6 speakers in it anyone know for sure what size they are. Some website say 5 1/4 some say 6 1/2.i Know the back is 6x9s.
ethan is offline   Reply With Quote
Old 12-29-2008, 03:21 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
6 1/2's fo sho. i suppose 5 1/4 would fit but you'd have to drill new holes I think. 6.5's should be a direct fit though
TrdSpeed140 is offline   Reply With Quote
Old 12-29-2008, 06:08 PM   #3 (permalink)
JUNIOR347's Avatar
View JUNIOR347's Photo Gallery
Check here
http://www.crutchfield.com/S-dfixDAS...car/mycar.aspx
JUNIOR347 is offline   Reply With Quote
Old 12-30-2008, 07:06 AM   #4 (permalink)
'11 Camry
View JasonA's Photo Gallery
The Crutchfield site lists both 5-1/4 and 6-1/2 for the front doors, and all three: 5-1/4, 6-1/2, and 6x9, for the rear deck. Clear as mud.
JasonA is offline   Reply With Quote
Old 12-30-2008, 05:29 PM   #5 (permalink)
JUNIOR347's Avatar
LOL you're right i thought he wanted to know what did fit.I guess next time i'll read the post better lol
Old 01-07-2009, 11:30 AM   #6 (permalink)
View mtnbiker3000's Photo Gallery
Talking
I just did a complete speaker swap on my '04 S. I used Infinity Kappas all the way around and they do sound pretty good...
The rears are 6X9's and not too bad to install yourself. The hardest part is actually mounting them in the deck since the screw holes don't match up, and it's a tight squeeze to get hands/tools in there. I bought some adapters on E-bay for $10, but didn't end up using them even though they seemed like they would have worked well.
The fronts are 6.5" components. A little more involved here, as to truly get an improvement in sound you need to do some work.
-Drill out & remove the OEM plastic rings/speakers in the doors. You will never get good sound by just inserting new speakers in the old rings.
-Cut & route some MDF to bring the speakers 'out' to the proper distance from the door.
-Use some Dynamat both in the door cavity and behind the speaker at least. The more the better, but it is expensive.
-Find a good dry and secure place for the crossovers inside the doors.
-Use a dremmel or similar tool to clear out the inside of the wing panels for the tweeters, as the new ones are quite a bit bigger than stock. You may need to use a glue gun to secure them.
-I attempted this job a couple of times, but in the end I just had a good stereo shop do it all for $150 including dynamat. Unless you have an extensive shop and tools, it is a tough job to do right. Plus, now it is guaranteed for as long as I own the car. Any issues and I just bring it to them instead of give myself an aneurism trying to fix it...
Pushing all 4 speakers with a Kenwood 4 channel amp at 100 watts / channel. The Infinity's are nice cuz they run at 2 OHM's (more power) Also, have a RF Punch 10" Stage II sub with a seperate amp. All together a nice upgrade without breaking the bank...
Oh, and also using a Kenwood 438U deck. I like this one cuz it has 3 sets of preouts. 2 sets for a four channel amp (can use the fader) and 1 set for the sub (this deck also has a seperate sub volume). And the USB input on the face is nice too...
mtnbiker3000 is offline   Reply With Quote
