coolant bleeders????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2009, 02:30 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
2004 corolla. does it have coolant bleeder screws ? want to be sure no air in the system after coolant change.
6&8.
jamesmetairie is offline   Reply With Quote
Old 01-14-2009, 06:51 AM   #2 (permalink)
View dorman68's Photo Gallery
I have a 05 Corolla and could not find any coolant bleeders. I just loosen the upper rad hose or one of the heater hoses to remove air from the system, it may be a little cumbersome but it's the only way I could think of.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-18-2009, 04:55 PM   #3 (permalink)
HondaGirl fixin bf toyota
View 96integ_chick's Photo Gallery
What do you mean loosen the upper radiator hose? Wouldnt just leaving the cap off the rad bleed the system without bleeder screws?
96integ_chick is offline   Reply With Quote
Old 01-19-2009, 06:23 AM   #4 (permalink)
Leaving the cap of for the initial fill with the engine off would help. After draining or flushing the cooling system air pockets can be trapped in various spots through out the block, heater core and radiator. The best solution that I could think of was after filling up the cooling system put the cap on and let the engine run and get to operating temperature, once the vehicle is up to temp the coolant should begin to circulate after the thermostat opens. Once the coolant is circulating most likely the air pockets will move areound in the system, I replaced the original spring loaded rad hose clamps with a worm drive type so I could gradually loosen the upper hose clamp to release any trapped air.
Old 01-19-2009, 10:44 AM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
That's not necessarily true, sometimes the air bubbles are trapped before the thermostat and it doesn't open because no hot water is passing through, that's why most bleeder screws are on top near the goose neck/thermostat area!
Raddman is offline   Reply With Quote
Old 05-24-2010, 07:24 PM   #6 (permalink)
juicedz's Avatar
View juicedz's Photo Gallery
I'm bringing this post back from the dead because the above methods mentioned do not really answer the question on how to "properly" bleed the system of air without bleeder screws being available.
2003 Toyota Corolla S
juicedz is offline   Reply With Quote
Old 05-26-2010, 09:38 PM   #7 (permalink)
juicedz's Avatar
ttt
Old 05-26-2010, 09:58 PM   #8 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Drain system, fill up rad, leave the cap off, start car, turn on the heat on high, refill when level drops, repeat until level is correct, and watch the level for a few days. The rad cap is the highest point on the system.
mikered30 is online now   Reply With Quote
