Rack & Pinion Replacement? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2009, 10:34 AM   #1 (permalink)
ttd
View ttd's Photo Gallery
I've recently taken my car for a wheel alignment to a local shop, and after watching them go back and forth with the car doing 2 road tests, they came to me and said, "my bushings have worn off" and that "the only solution would be a replacement of your rack and pinion" they finished the alignment and still the steering wheel is a bit off. The next day I took it to the dealer hoping they would goodwill a replacement but after getting their invoice they said nothing was wrong with the rack and pinion. However, I'm still worried because on their invoice it said "check for rack and pinion leaks" and "steering/suspension check". Who should I believe? And is my steering wheel ever going to be completely straight when I drive foreword, I mean I know there is a crown on the road but I've drive the car with a completely straighten steering wheel and have it do just that before.
ttd is offline   Reply With Quote
Old 01-06-2009, 12:04 PM   #2 (permalink)
View tarbasd's Photo Gallery
If my understanding is correct, the dealer checked the rack and pinion (as they say it on the invioce), and found no problem. I would believe it. The local shop probably wanted to rip you off. The steering wheel alignment is a different problem. Take it to the dealer (or an independent shop - but I wouldn't trust the alignment place) and tell them the problem. It should be easy and cheap to fix it.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 01-07-2009, 07:45 AM   #3 (permalink)
Banned
View bbsgarage's Photo Gallery
^^^^^^^^What he said ^^^^^^^
bbsgarage is offline   Reply With Quote
