I believe the stock speakers in mine, in the rear anyways were rated at 17.5W each. My new ones are 300 peak, 60 cont. But as I said I also replaced my head unit. I also just looked at the stock radio...no amp ratings, but it does say 4-Ohm speakers. Hope this helps. Getting the rear deck out sucks too by the way...well in an 08 anyways. If you have any questions about it just ask.
BTW : 4-Ohms at 12V is 36 Watts...So it seems that the stock radio is rated for 36W Max. Per Speaker I presume. That being said, it will still power 50 rms, up to a point. But i assume that you dont go around with the volume all the way up...hopefully.
Reason: Added info
