Help '05 S No Spark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2009, 09:15 PM   #1 (permalink)
KA8
View KA8's Photo Gallery
Help '05 S No Spark
The car ran fine, park it for about 30min then it didn't start.
I'm getting Fuel but no spark. If it sits for a while and you try to start it will start and run for 1 second and die, after that it just cranks.
I replaced the cam and crank position sensor with new OEM toyota parts.
I checked the timing chain and it still intact.
Is there anything else to check before comming to the conclusion that the ECU is bad?
119,000 on the clock
Thank You
KA8 is offline   Reply With Quote
Old 01-13-2009, 09:28 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Thank You
Any CELs? I assume you check the coil packs and plugs?
mikered30 is online now   Reply With Quote
Old 01-13-2009, 09:33 PM   #3 (permalink)
KA8
No CEL, sparkplug looks ok and I didn't check the coil packs cuz i figure they all can't good bad at the sametime.
