Check Engine Light Codes Help???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2009, 11:08 PM   #1 (permalink)
View mannydhanju's Photo Gallery
USA Check Engine Light Codes Help????
I have 2003 Toyota corolla and i got these codes that came up with my reader...
PO776- shift solenoid
P0441_ evaporate emission system incorrect purge flow
P0446- evaporate emission system vent control circuit
P0440_ evaporate emission system
I need help or guidance on how to fix these things please... your help would be of much use....
thnks Toyota owners.
mannydhanju is offline   Reply With Quote
Old 01-14-2009, 11:19 PM   #2 (permalink)
just a nobody
Now that you have the codes, just clear them and see which one comes back. P0440, P0441, P0446 are possibly cause by a loose gas cap or a evap system vent valve or hose problem. P0776 is not a valid code; however, if it is a P0770, there may be a TSB for that concern, http://matrixowners.com/tsb/T-EG020-02.pdf.
N.E.O.
Old 01-14-2009, 11:37 PM   #3 (permalink)
cool thanks.. So as far as that tsb goes i have to go to Toyota to get the parts... and how do i replace the gear stuff and is that located on/in tranny..
Old 01-14-2009, 11:43 PM   #4 (permalink)
just a nobody
If that is indeed the problem that you are having, then yes. That was just for reference, you may have to do some diagnosis first. Depend the on the mileage, some of the the parts might still be under warranty, like the ECM which is 80,000 miles or 96 months, the other parts a under the powertrain warranty, which would be 60,000 miles or 60 months.
N.E.O.
Old 01-15-2009, 12:00 AM   #5 (permalink)
i have 100+ miles on it so warranty.... do you know how to fix that stuff.
Old 01-15-2009, 12:05 AM   #6 (permalink)
just a nobody
According to the TSB, the only cheap repair is the speed sensor, everything else if you need more than the speed sensor, it will be above a thousand dollar. On the other hand, if your car has more than 100k, then chances are that the TSB isn't applicable to your vehicle. Should just go with the diagnostic procedure for the code. Have you verify what that code is, if it is not P0776?
N.E.O.
Old 01-15-2009, 12:14 AM   #7 (permalink)
yea the code is 90770... so what do you think I should do.
Old 01-15-2009, 12:20 AM   #8 (permalink)
just a nobody
Clear the codes and see which one reset first.
N.E.O.
Old 01-16-2009, 02:42 PM   #9 (permalink)
ok guys.. after runnning around trying to find out the P07770 code... i found out that it is the shift solenoid no.3... toyota wants $260 for the part (WOW)... and in town people want 200 to install... so i am back here once again... does anyone know how to install and how hard it would be... me and my freinds work on honda/acuras but never messed with a auto tranny... is there so advice or guide someone can give on how replace this solenoid and/or where to get the part cheaper...
thnks
Old 01-16-2009, 05:32 PM   #10 (permalink)
mikered30's Avatar
Gameroom cash: $532567
When was the last time you changed your tranny fluid? Ever? You can get the part from 1sttoyotaparts.com for cheaper, i am pretty sure the part number is 35250‑12030. Check out http://www.toyodiy.com/parts/p_U_200...html?hl=35250A for the location.
mikered30 is online now   Reply With Quote
