help me plz!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2009, 12:38 AM   #1 (permalink)
View corollas03silver's Photo Gallery
help me plz!!!!!!!
hi i changed the oil on my sisters 2003 corolla s. i think i put too much oil. when she was driving the car was jerking and a CEL lit up on the dash. i tried draining some oil. now when i put the car in drive or reverse it does nothing like its in neutral. wut can i do???? also when idleing it drops to around 500rpm and feels like its about to stall out.
corollas03silver is offline   Reply With Quote
Old 01-16-2009, 12:52 AM   #2 (permalink)
just a nobody
Where did you take the drain plug out from? The driver's side of the car or the passenger side? What color is the fluid that you drain out?
N.E.O.
Old 01-16-2009, 05:32 AM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
How much did you put in? From the symptoms your described, it sounds like the oil got past the seals that hold the oil from going places it should not. Her car probably had a lack of oil pressure. Can you pull the spark plugs to see if they are coated in oil?
mikered30 is online now   Reply With Quote
Old 01-16-2009, 07:29 AM   #4 (permalink)
just a nobody
From what he described, he may have drain the transmission fluid and overfilled the engine with oil.
N.E.O.
Old 01-16-2009, 09:50 AM   #5 (permalink)
i drained from the driver side. the color was a dark brown. then i added about 4 qt of oil.
Old 01-16-2009, 10:40 AM   #6 (permalink)
'11 Camry
View JasonA's Photo Gallery
It does sound like the transmission fluid was drained out, rather than the engine oil.
Drain all the oil from the engine (this is the drain plug on the passenger side of the car) and re-fill with 4 quarts. I'm not sure how much transmission fluid the transmission takes. Does the 2003 model take the T-IV fluid?
JasonA is offline   Reply With Quote
Old 01-16-2009, 11:11 AM   #7 (permalink)
just a nobody
Put 3 qts of Type T-IV transmission fluid in and then check it, probably take about 3.7 qts.
N.E.O.
Old 01-16-2009, 04:14 PM   #8 (permalink)
View jeepwranglerg's Photo Gallery
I made this mistake!!!!
Its hard enough to get under there and see what your doing. I undid the auto tranny and the fluid was brown i figured engine oil wrong!!! You better dump engine oil and autotranny fluid!!! I went to dealer for correct fluid i think took three quarts but have some left over!!! 2.7ish not sure! Ive been changing oil for years as well all my jeeps where easy put a 5gallon can underneath lots room! This sucks dood your tranny maybe broke now. Dont let her drive or start it ok!
jeepwranglerg is offline   Reply With Quote
Old 01-17-2009, 03:01 AM   #9 (permalink)
View downhill1956's Photo Gallery
A joke
Seriously, is this a prank post? If not, you should not be working on anyones car. Take it to the dealer or at least jiffy lube. Every indication is that you my have done serious damaged to the engine. The car won't move as it does not have trans fluid.
downhill1956 is offline   Reply With Quote
Old 01-17-2009, 06:13 AM   #10 (permalink)
View dorman68's Photo Gallery
N.E.O.
I think you did the same thing as N.E.O. mentioned. Check your trans fluid level.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
