brake ! need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2009, 10:04 PM   #1 (permalink)
View elbandrawy's Photo Gallery
brake ! need help
I have 05 corolla, it has 111 K. I checked the brake pads and rotors and they look fine. lately when it starts to be cold, when I push the break I hear like cliking and increase with the speed. some times it disapear then comes back. I can notice it very well at low speed. I checked today the tires presure and balance but they are ok. It is just the clicking sound nd there is no problem with hte functionality of the brake itself. Please help in estemating the reson behined this sound and what might be the possible solutions
thanks
elbandrawy is offline   Reply With Quote
Old 01-17-2009, 06:17 AM   #2 (permalink)
View dorman68's Photo Gallery
Possibly the pad shims are loose from the pad or bent.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-17-2009, 07:47 AM   #3 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
Maybe its the ABS kicking in?
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 01-17-2009, 09:03 AM   #4 (permalink)
View jonjoe's Photo Gallery
European Union hey
i know this mite sound stupid but i had that problem same car and year if you have hubcaps and have ties on them it could be that it could be the ties holding the hubcaps on they could be hitting off something on the inside i tuck the ties of mine and the clicking went worth a go..also check for small stones stuck in the treads of your tyres......
jonjoe is offline   Reply With Quote
Old 01-18-2009, 12:02 PM   #5 (permalink)
View tarbasd's Photo Gallery
It sounds like your ABS. If it kicks in when the road conditions are good (not slippery) and your don't go fast, then it is likely that one of your ABS sensors is sending wrong signal to the computer. Have it checked out, because it may cause a loss in braking efficiency (which may not be noticeable at this point).
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 01-18-2009, 10:39 PM   #6 (permalink)
RE-brake problem
I donot really feel that the ABS try to stop the car or any thing. the brake efficiency is very good. it is just that sound when I apply the brake. it is a clicking sound similar to the sound when you drive with a flat tire but lower in volume.
