Originally Posted by masterjedi73
I need an entirely new storage compartment for the section underneath the radio. Both door hinges are broken and just flop open. Where can I get this online? Is it called something different, cause I can't find it.
Thanks!
I think a big % of ninth generation corollas happened to have that problem, lots of threads on that here especially for the top one(under the climate control) because it has a cheap plastic tab that holds the springs on both side and breaks easily, but I never heard of the bottom one breaking, I might be wrong but I think that and the coin tray(left side of your steering wheel) are like gravity closed, when you push on it it falls into place as to the middle one where it pulls closed by springs...Toyota wants around a $100 for a new one, I just rigged a heavy duty rubber band in back, it's held for the last two years and works great/doesn't show! I think it's called a radio or a dash console but I'm not sure, you would have thought Toyota would have fixed this frequent problem in their later ninth generation cars...
I don't know if they make an aftermarket replacement, best bet is to try the boneyards!
