P0135 code of 03 Toyota Corolla
Hello Friends,
My name is JERRY. I am a new member in this forum. HAPPY NEW YEAR TO EVERY ONE!
My first question is about P0135 engine code of 2003 Toyota Corolla.
When I started the engine at a cold engine temperature, the engine light turned on and the code was P0135. After running the engine for about 5 or more minutes, I stop engine and disconnected the negative battery terminal for about 20 seconds or more, then I re-connected the negative wire back to the negative terminal of the battery. After doing that, I started the engine again at a warm engine temperature, so the engine light went off and the P0135 code disappeared. The disappeared engine code P0135 will come back again when I start the engine at a cold engine temperature.
Would you please help me to find out what cause the engine code P0135 on?
Thanks for your time and help in advance.
Jerry
