Originally Posted by quanius
I have two Corollas.. 2004 is great. Heater and AC are sufficiently powered. I have noticed however on my 2008, during these winter months up here in NH the heater takes much longer to get the car to a tolerable temperature. I have even noticed when I put the fan on full the engine temperature indicator will drop!
Anyone else having these issues? I am wondering if it is designed weak or if I have a defective climate system.
Should be the same, since the 04 and 08 have the same mechanicals. If it is really cold out below 5 F, my '99 Corolla engine temperature will drop a little if I turn on the heat, but it eventually gets back up to normal. Another possibility is the coolant mixture strength. I think if the antifreeze is too high, the heater will not put out as much heat.
