very loud valve tap on 1zz fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2009, 03:12 PM   #1 (permalink)
View Kaiser01's Photo Gallery
USA very loud valve tap on 1zz fe
I have a 2005 corolla s with 115k miles. I change the oil every 5k. Recently I started hearing a loud tap under the hood. I stopped at a gas station to check it out. The dipstick was out and I was a quart low I was only 2 miles from home so added a quart of 5W30 & headed home, by the time I got home the tap was very very loud. I check we the compression everything checked out. Check the valve clearance ex was .009 across the board the intake was .007 on all but one which was .006 inches. My haynes manual seemed to print the correct valve clearances but I saw one for an older model and they looked very close. The sound is louder when it fiest starts up and quiets down once the car is warm but as soon as i step on the gas it gets just as loud. I would like to bring it to the dealer but scared to drive also wanted to see if there might be something with the vvti or something off the wall any help soul be greatly appreciated
Kaiser01 is offline   Reply With Quote
Old 01-20-2009, 03:49 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Check the serp belt for deflection.
mikered30 is online now   Reply With Quote
Old 01-20-2009, 04:37 PM   #3 (permalink)
Yeah that was the next thing after the oil
I wish that was it
Old 01-21-2009, 05:10 AM   #4 (permalink)
View dorman68's Photo Gallery
Check your belt tensioner. I would remove the serpentine belt and run the engine (for no longer than a minute as the water pump is now not rotating) and see if the sound goes away. If it goes away with the belt off then your tensioner is the culprit.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-21-2009, 03:59 PM   #5 (permalink)
no go on the tensioner good idea though
The sound is much louder then I've ever heard from a belt. I am almost 100% it's internal
Especialy after removing the belt
Thanks anyway
Old 01-22-2009, 06:36 AM   #6 (permalink)
Thanks anyway
I was hoping that would be your problem as it would of been an easy fix. After eliminating the belt tensioner from your diagnosis I would probably suspect a timing chain or guide issue.
Old 01-24-2009, 11:11 AM   #7 (permalink)
Question
Thank to mike I just found out my exhaust clearance is off .001" the specs say it should be .0098" and mine are all at .009. Two questions
1. would this cause a very loud valve tap
2. Would you think this is the lifters or cam or something else all together
Old 01-24-2009, 03:30 PM   #8 (permalink)
just a nobody
That amount is not going to cause noise during cold start, I would suggest look into or think about changing the timing chain tensioner. The tensioner would be more likely to cause a short rattling noise during cold start, and often times there wouldn't be any further noise until the vehicle has sat overnight or for extended period of time.
N.E.O.
