Snappy little motha, i test drove a new 2007 corolla ce with manual trans what a dog! Id easy i mean easy beat that in race.
So its not the tranny, what type of automatic fluid did you install and do you know how to read the dip stick. There's a cold with two lines one high one low, then there's high mark with two dashes ones hot full other hot low. Only use toyota brand fluid will be marked with scion on it. I had similar problems with tacoma i had with automatic wished id stuck with factory stuff.
You might need some new o2 sensors, if your running rich that would be why your slow?
Clean the maf, get the right cleaners there spendy but you cannot use carb cleaner to ruff.
