Heater issues in the cabin: help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2009, 10:25 AM   #1 (permalink)
View DrPils's Photo Gallery
Hey folks
Have a 2003 corolla and am having insufficient heat coming out of the vents, which makes it a little uncomfortable as I live in Michigan. I took it to my mechanic; he said the fluids and hoses were in good shape. He took the temp. of the vent air and it only reach around 85-90 degrees (he says it should be 110+). He suggested that I go to a place in town that specializes in radiators. The engine temp. gauge is in its normal position so the engine itself is getting warm. The problem is this heat is not getting transferred efficiently to the cabin heating system.
A friend said it may be the temperature sensor...
Any suggestions or thoughts would be well appreciated!
DrPils is offline   Reply With Quote
Old 01-30-2009, 11:21 AM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by DrPils View Post
Hey folks
Might be your thermostat is opening too quickly or your heater(under dash) isn't fully engaging/opening! I have an 03 and I get good heat when it hits normal temp it's blistering no matter what the outside temp is, I just wish my corolla had a stronger fan, sometimes I have to go to the highest fan setting just to get a good flow of air even when using my AC!
Raddman is offline   Reply With Quote
Old 01-30-2009, 03:35 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Does your temp gauge get up to normal?
mikered30 is online now   Reply With Quote
Old 02-01-2009, 03:33 AM   #4 (permalink)
View Volvosteel's Photo Gallery
Thermo
I would deff check your thermostat, its just as common for them to open early as to not open at all, it is considered a failure and these are normally pretty inexpensive item's to replace and are a DIY item.
As for the other poster on the weak fan, i agree, when i am driving around in the summer time in temps exceeding 120 it would be nice if the Ice Cold air comming from my A/C would blow just a little harder into the cabin, ive thought about replacing it with some aftermarket until that will spin faster.
Volvosteel is offline   Reply With Quote
Old 02-02-2009, 10:06 AM   #5 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
I will take an infared temp of my heat today when I drive home so you can compare.
Rdkill is offline   Reply With Quote
Old 02-03-2009, 05:24 PM   #6 (permalink)
10' Corolla S
OK mine puts out, at the vent, full heat around 170F to 180F.
Old 02-13-2009, 06:32 AM   #7 (permalink)
View dorman68's Photo Gallery
Possible partially clogged heater core or kinked/binding temperature control cable causing the door under the dash not to operate properly.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 11-22-2010, 04:20 PM   #8 (permalink)
View willy65000's Photo Gallery
where is the temp control cable?
willy65000 is offline   Reply With Quote
Old 11-24-2010, 09:17 AM   #9 (permalink)
It runs from behind the control knob assembly to the heater door. Your best bet would be to remove the heater control assembly.
