Originally Posted by cricketislife
I was able to remove the entire console with the storage compartments. It is much easier to work on this now. I have glued the two plastic thingys. But this is temporary only. Is there a permanent solution to this issue besides replacing the entire panel?
Thanks.
I tried gluing mine but the part is small and there is spring tension on it, and it broke the first time I tried to opening it, my one side broke years ago and I used a strong rubber band on it stretched across the back and it has held up ever since with the door working perfect, there was a thread a few weeks ago on the same subject I suggest you look for it, one guy velcroed it shut and a few had other ideas that they said worked, one even glued the door shut forever, this is a very common problem on the ninth generation corolla...good luck
BTW I first tried velcroing mine but it didn't work for me
