uummm
Well my 2003 has never been in anything under 20, but i do have a 5sp with 215K on it, im only on my second clutch, as for engagement with car in neutral i have noticed that from time to time it seems it still catches alittle, simply pushing the clutch back in and letting it out again solves the issue, though this does not happen very often. If you are on your original clutch its probly time to have it replaced, you may be grinding the clutch plate itself down, have it checked to see where the clutch itself stands wear wise. BTW my 2003 has probly seen the hotest temp's out of anyone's, in the summer it reg see's temp's close to 130, at those temp's under stop and go type condition the clutch does begin to slip alittle.
