Battery / Alternator / What Else? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2009, 05:05 AM   #1 (permalink)
View PitBoss1's Photo Gallery
I have an '06 Corolla, with about 60k miles on it, nearly all highway. I work nights, and commute 100 miles round-trip. I have an after market radio in the car, a pioneer, which I use to listen to my iPod. I am in the habit of leaving the iPod plugged in, and in the glove box all the time. I have had this setup for about 8 months now. I am mentioning the iPod setup as it is the only thing that is not 'stock' in the car. I am fairly certain that it is not at fault for my problem.
I left for work in the early evening, and the temperature was about 55 degrees or so, with light rain. I noticed no problems at all as I pulled into my parking spot at work.
When I went to my car after work at 02:30 am (35 degrees) I noticed that the keyless entry didn't work. I had to manually unlock the door. Turning the key yielded the usual dashboard lights and the bells that indicated that my seatbelt was not yet fastened. Then when I tried to start it nothing happened at all. No solenoid click - nothing. I got a jump from the security folks at work, and it started right up.
I made the 50 mile drive home, and noticed that if I applied the brakes, the headlights would dim. When a turn signal was blinking, there was a slight dimming of the headlights in time with the signal. At one point, I turned the headlights to 'bright', and everything died immediately. I quickly turned them back to low as I coasted along, and it all came back up just fine.
After I pulled into my spot at home, I turned the car off. As an experiemnt, I tried to start it, and it behaved exactly as it did when I first got into it after work - nothing would start.
My question is this: Is it just the battery, or could the alternator be at fault as well? Or something more sinister?
One odd thing - none of the usual idiot lights came on to indicate any problems. No battery light, no alternator light, nor a 'check engine light' - nothing.
PitBoss1 is offline   Reply With Quote
Old 02-02-2009, 07:36 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
Seems like the battery. The alternator is supplying enough to keep the car running, but the battery's not there to start it. I would have the car jumped and make a trip to Advance Auto or AutoZone, where they can test your battery and your alternator.
JasonA is offline   Reply With Quote
Old 02-02-2009, 10:34 AM   #3 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
Well the the problem is that if the lights are dimming when you activate brights, it very well could be both battery and alternator. If you have a bad battery, even really bad, the alternator should still put out enough power to run everything while the engine is on. Your battery is definatly shot(unless its relativly new), but I would say it could be the alternator as well. Make sure you have BOTH checked. If you replace the battery and keep a bad alternator it will kill it rather quickly as the battery will not be getting a full charge. If you take your battery voltage at the terminals with the engine running, it should be 14.4 for a perfect alternator. We had a bad alternator put out just 13.8 and when tested it was putting out 50% rated power....
Rdkill is offline   Reply With Quote
Old 02-03-2009, 12:45 AM   #4 (permalink)
Replaced the battery, and it seems to be OK for now.
Old 02-03-2009, 12:22 PM   #5 (permalink)
'11 Camry
I would have the alternator checked as well. There may have been a reason the first battery died.
Old 02-04-2009, 03:16 AM   #6 (permalink)
I did get the alternator checked, at Autozone of all places. Yea, I know - they aren't really professional mechanics there, but the guy seemed to know how to read the machine that he clamped onto my battery cables - my apologies to dedicated Autozone employees all over the world, but the dude was reticent to attach the machine in the first place. His initial diagnosis of my problem was that I had a short, and I had to talk him into hooking up the device. I got the distinct impression that he may have been stoned - or constipated, I couldn't really tell. Understand - he was already outside, finishing the same procedure with another customer. At any rate, the alternator's good-to-go.
Old 02-04-2009, 06:17 AM   #7 (permalink)
'11 Camry
I used to work at Advance...I know how it is with most of those guys. Either way, it's pretty hard to mis-read the machine, so if the machine said your alternator is fine, it most likely is.
