Please Help....Corolla Brakes Clicking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2009, 09:02 AM   #1 (permalink)
JE8
JE8's Avatar
View JE8's Photo Gallery
I did a front brake job on my 05 Corolla.....brakes work well...EXCEPT...at about 15-20 mph...the brakes make a clicking noise wjen LIHGTLY applied.
I've taken them apart several times and re greased....and YES I'm using anti squeal on back of pads
Please help.....this clicking is driving me crazy !!!!
THANK YOU !~!!!!!!
JE8 is offline   Reply With Quote
Old 02-05-2009, 12:43 PM   #2 (permalink)
Banned
View bbsgarage's Photo Gallery
the pad may be slightly loose or simply does not fit right and moving under light braking.
bbsgarage is offline   Reply With Quote
Old 02-05-2009, 01:17 PM   #3 (permalink)
JE8
JE8's Avatar
I used real Toyota pads....how can i fix it if they are loose?? Thank you!!!!!
Old 02-05-2009, 02:01 PM   #4 (permalink)
View Axxis8203's Photo Gallery
did you replace the rotors? if not then you will need to do so.
did you have the rotors ground? if so, then they are probably too thin.
have you done a bedding in procedure with the new pads?
Axxis8203 is offline   Reply With Quote
Old 02-05-2009, 02:42 PM   #5 (permalink)
JE8
JE8's Avatar
Yes the rotors were turned and seem fine and yes to breaking in the pads.....
When I take the brakes apart and grese evrey thing up...they are fine for about a month...and then the clicking comes back.....low speeds/light pressure
It really sounds like the pads moving around....but everything looks OK
I've taken them apart a couple of times......and it still comes back
Its got to be something simple...but I just can't figure it out
Help !!!!!!!
Old 02-05-2009, 05:41 PM   #6 (permalink)
View 2008TRDCorolla's Photo Gallery
I have the same problem
When I am braking lightly, it sounds like the brake pads are grinding - I don't know what it is... I took my wheels off and checked if the brake pads are worn but they aren't... They still got about 50% life... I am curious as to what it is... My car is a 2008. What year is yours?
2008TRDCorolla is offline   Reply With Quote
Old 02-05-2009, 09:45 PM   #7 (permalink)
is there any possibility this sound may be coming from the rear brake drums?
Old 02-05-2009, 10:05 PM   #8 (permalink)
That thought actually came to my mind... I started reading about drums and how you should get them tightened? Somewhere along those lines, something like that... I was gonna take the rear wheels off soon and check it out (maybe after buying a Chiltons or Haynes manual or just take it to the mechanic.) It could be very possible... The car is nearing 18K, you think I would need to do something with the Brake drums already? I do not drive this car aggressively... It is my daily driver and I kinda baby it. I want it to last 3 or 4 million miles (sarcasm)... Let me know what you think.
Old 02-06-2009, 01:33 AM   #9 (permalink)
JE8
JE8's Avatar
Unfortunately, my Corolla is front brakes clicking....when I take them apart and apply grease they are perfect....for about a month or so....then the clicking returns.....its making me crazy !!!!!!!!!!!!!!
HELP !!!!!!!!
Old 02-06-2009, 12:20 PM   #10 (permalink)
Banned
i seem to remember some type of shim that clips on the end of the pad to take up some slack, this may have been brand specific though.
too many cars under the bridge to remember which one it was.
Old 02-07-2009, 09:11 AM   #11 (permalink)
JE8
JE8's Avatar
I used Toyota Pads and they fit into the holder rather snugly....so I just don't understand why they would be clicking/moving
I cleaned and lubed the slider pins...they look perfect
It only happens at low speed/light pressure
HELP
Old 02-07-2009, 10:20 AM   #12 (permalink)
After further investigation, I have concluded that it is def. coming from the front of the car... Only in light braking also... Do you think we should take it to Toyota and they will cover it under the warranty?
Old 02-09-2009, 06:53 AM   #13 (permalink)
Banned
Now thats funny.
if its bothering you that much, take it to a pro.
Old 02-09-2009, 07:31 AM   #14 (permalink)
yes at 18k i doubt that it would be rear brake related, but it's still possible though.
it's still under warranty, and so taking it to a toyota dealer you trust might be a good idea, that way if the problem comes back whatever they do will be under at least a 12month/12k warranty.
down side to this is that they may want to do another brake job which you'll have topay thier ridiculous prices for.
Old 02-09-2009, 10:28 AM   #15 (permalink)
Banned
I highly doubt they will warranty the brakes after he did a repair to them.
unless it is a mfg defect which I do not believe it is.
