cel on= - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2009, 06:27 AM   #1 (permalink)
View jamesmetairie's Photo Gallery
cel on=
2004 with 96,000 miles.check engine light just lite up. is there a usual problem?
6&8.
jamesmetairie is offline   Reply With Quote
Old 02-13-2009, 08:46 AM   #2 (permalink)
Banned
View bbsgarage's Photo Gallery
could be anything really.
most likely an O2 sensor.
go to you local big box mc-auto center they usually will check out the codes for free.
that will tell you exactly what the problem is.
bbsgarage is offline   Reply With Quote
Old 02-13-2009, 04:36 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Autozone or advance will check it for free. They will give you the code and a likely cause. Post it back on here.
mikered30 is offline   Reply With Quote
Old 02-13-2009, 11:17 PM   #4 (permalink)
cel . code reads==
1) PO171, system too lean (bank 1)
2)PO133, 02 sensor ckt
slow response (bank 1 sensor 1).
awhile back i read a post somewhere about how to access the 02 sensor to replace it. something about going at it thru the paassenger side ,front under the carpet??
anyone have their corolla totally stalll becuse of any "cel" ?? i,ll keep you guys posted as things progress .
6&8.
Old 02-14-2009, 01:32 AM   #5 (permalink)
just a nobody
There are TSBs for both codes that you have listed: http://www.justanswer.com/uploads/sk...olla_po133.pdf and 'toyota.justanswer.com/uploads/skyvisions/2008-04-05_204452_04_rolla_0171.pdf'. Not sure if it is applicable to your vehicle, but won't hurt looking into.
N.E.O.
Old 02-14-2009, 07:52 AM   #6 (permalink)
mikered30's Avatar
Both codes point to the front O2 sensor (not the one where you remove the carpet), although the P0171 code is very broad. Check out the TSB first.
Old 02-19-2009, 10:27 AM   #7 (permalink)
View dorman68's Photo Gallery
The intake manifold gaskets are very common for causing this symptom.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 02-23-2009, 04:45 PM   #8 (permalink)
booged down at 30mph=
another symptom= couple of days ago at around 30mph car refused to gain any more speed even with pedal to the metal. also driver comp[lained of a gasoline smell in the car. also whem driver exited the parked car noticed another gasoline smell. i drove the car the next day and no symptoms observed. "cel"still shining bright. when i get time to fix it i,ll post the results.
6&8.
