normal rpm,s=??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2009, 10:10 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
normal rpm,s=???
2004 with automatic tranny. dealing with "cel" nowadays. cleaned maf today. cel disapeared for now. with engine normal temp with the a/c on parked with tranny in "drive" i noticed rpm,s sitting on about 900 . idle seemed to be a little rough. at that low idle is it possible that the alternator ain,t charging the battery. for example if you was stuck for 10 hours in hurricane evacuation would it kill ? soon i,ll replace the a/f sensor. will keep you guys posted. have a good weekend !
6&8.
jamesmetairie is offline   Reply With Quote
Old 02-27-2009, 10:35 PM   #2 (permalink)
View toyomoho's Photo Gallery
The alt might put out 1/2 its max current at idle. If 80 amps this would be 40 amps. If you exceed this load at idle the battery will eventually go dead.
Get the code read to save time.
Old 02-27-2009, 11:38 PM   #3 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
Have your charging system load tested as well - free at most large parts stores. I'll checked my stats tomorrow and reply back with the RPMs - if that's any help.
BTW: I have a daughter going to Tulane... she (and we) love the area and all that it has to offer.
GK
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 03-05-2009, 12:35 PM   #4 (permalink)
NMGeorge's Avatar
I checked my car yesterday - sorry for the delay.
Anyway, I am smooth as glass at 900 rpms. How do your plugs look?
Good luck - and I got your email, thanks!
George
George
2007 Corolla S
Old 03-05-2009, 12:58 PM   #5 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
Do you have the 1zzfe or 2zzge motor?
XR2003 is offline   Reply With Quote
Old 03-05-2009, 01:24 PM   #6 (permalink)
1zz
it,s a base 1zz engine,corolla "ce". i will check the plugs as NMGeorge suggested.thanks for the help.
6&8.
Old 03-05-2009, 05:12 PM   #7 (permalink)
XR2003's Avatar
the 1zz is known to idle "weird".
you can look into cleaning the throttle body or if you have the DBW kind - perhaps cleaning around the IACV and PCV.
Hope you find the cause for your symptoms.
