03 corolla manual transmission going bad
I have an 03 corolla with manual transmission that is exhibiting problems similar to what I've read on other postings. The transmission makes a growling, rattling noise when it is in gear and the clutch is out. It definitely sounds like a bearing is going bad, similar to others postings. Car has 125,000 mi.
My question is, is it to my advantage to replace the bearing now, or should I just wait until the transmission totally self-destructs and get a new one at that time? How involved is the bearing replacement? I'm not sure which bearing it is, but hopefully if you read my description above about the sound it makes, maybe you can tell. Is this something that should be left up to the mechanic or could I attempt it myself? My "most challenging" car repair to date is just brakes, struts and water pumps. I've never torn into an engine or tranny.
