Originally Posted by XR2003
Education or research? Either way the person will eventually look into HIDs instead of replacement halogen bulbs.
Which is fine as long as an HID conversion is done the right way. Too many people don't know that putting HID lamps into halogen light housings is a dangerous thing to do. Call it what you want, education or research. The result is the same either way: safer headlamps.
Why limit the choices available?
Don't limit the choices available, but make a comprehensive recommendation. If the recommendation is for HIDs, ensure that the recommendation is ALSO for projector housings at the same time. They should go together to be a safe solution.
Let the original poster of this thread decide what would be best by giving as much information as possible.
I agree: as much information as possible. Only when comprehensive recommendations are made, to include all parts necessary for a change, will a safe modification result.
Also for more ideas on headlight bulbs from other Corolla owners, check out 9 t h g e n c o r o l l a . c o m
That site makes my point about retrofitting HIDs into halogen housings. About half the folks on there have put HIDs into their halogen housings. You said I was "silly" for pointing out that you must use projectors for a proper retrofit, but improper retrofits are made all the time. Any measure of safety is always worth noting.
