Where's the MAF located? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2009, 10:37 AM   #1 (permalink)
View jkdrummer's Photo Gallery
A picture of the MAF's location would be helpful for the mechanically challenged. Is it easy to remove and clean the sensors?
Jk
Seattle
jkdrummer is offline   Reply With Quote
Old 03-11-2009, 11:05 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
It's located in the rubber intake tube, directly next to (to the left) of the black plastic air filter housing. I believe it's held in by two screws. It should be easy to remove the sensor, but before you try to clean it, I would ask what your reasoning is. Is the car hesitating or stalling? Is your check engine light on?
Welcome to the forum!
JasonA is offline   Reply With Quote
Old 03-11-2009, 11:10 AM   #3 (permalink)
P0171 -- but the car is running fine. I read somewhere a dirty MAF might clear this up. If it's the O2 sensor, where is that loacted?
Jk
Seattle
Old 03-11-2009, 12:06 PM   #4 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
P0171 System Too Lean (Bank #1)
XR2003 is offline   Reply With Quote
Old 03-11-2009, 12:18 PM   #5 (permalink)
XR2003 -- WOW! Thanks!
Jk
Seattle
Old 03-11-2009, 12:32 PM   #6 (permalink)
XR2003's Avatar
your welcome.
Old 03-11-2009, 05:43 PM   #7 (permalink)
'11 Camry
The front O2 sensor is right on the exhaust manifold. I think there's also a rear one after the catalytic converter. But I've also read that the front sensor isn't really an O2 sensor, that it's really an air/fuel ratio sensor. I'm still not real straight on the distinction there...
I'll look through my 2007 service information and see what Toyota's techs do for a P0171.
Old 03-11-2009, 07:13 PM   #8 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Check out this thread on your code: 2004 Corolla P0171 code (system to lean)
mikered30 is offline   Reply With Quote
Old 03-13-2009, 09:26 AM   #9 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
XR....are those aftermarket headers?
Rdkill is offline   Reply With Quote
Old 03-13-2009, 10:50 AM   #10 (permalink)
'11 Camry
That's the stock 2ZZ-GE aluminum intake manifold.
Old 03-13-2009, 05:10 PM   #11 (permalink)
XR2003's Avatar
correct
The 1zz has the black plastic intake manifold, while the 2zz has the aluminum intake manifold.
Old 03-13-2009, 11:09 PM   #12 (permalink)
View Flipinpride86's Photo Gallery
Would a bad MAF cause noticeable vibrations? would cleaning the MAF help if it is the cause?
Flipinpride86 is offline   Reply With Quote
Old 03-14-2009, 12:02 AM   #13 (permalink)
XR2003's Avatar
A bad MAF would cause the car to be unable to rev past 3k RPMS.
CLeaning the MAF might help, but please remember to disconnect the battery to avoid damaging the sensor.
Also disconnecting the battery will cause the ECU to relearn your driving behavior, which may help with the idle issue.
Old 03-14-2009, 01:16 PM   #14 (permalink)
View brad_i2001's Photo Gallery
If this helps, I cleaned mine at 31000 mi. I was getting around 28 mpg and now I am getting around 30 mpg like I used to.
brad_i2001 is offline   Reply With Quote
Old 03-19-2009, 08:54 PM   #15 (permalink)
View r0lla5XRS's Photo Gallery
Jk
Seattle
probably needs a intake manifold gasket. their on back order by the way.
r0lla5XRS is offline   Reply With Quote
