need help disabling day time running lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2009, 04:29 PM   #1 (permalink)
View Woot's Photo Gallery
How do i disable my day time running lights on my 9gen 08 corolla?, i have a HID kit and the DRL system is causing problems (flickering and random black-outs).
Ive had people tell me that i have to pull a fuse, but there is not DRL fuse, or i cant find it, HELP!
Woot is offline   Reply With Quote
Old 03-18-2009, 05:37 PM   #2 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
DIY: 2003 matrix xrs disabling DRL's
should still be the same for Corollas. . .
Cut PIN 12.
Done
XR2003 is offline   Reply With Quote
Old 03-18-2009, 08:50 PM   #3 (permalink)
00 rolla VE
View huangxin's Photo Gallery
wouldn't it be a lot less hassle to just pull the DRL fuse from the box?
huangxin is offline   Reply With Quote
Old 03-18-2009, 09:20 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Nope, does not work.
mikered30 is offline   Reply With Quote
Old 03-19-2009, 08:41 PM   #5 (permalink)
View r0lla5XRS's Photo Gallery
this is by-far the most easiest way to disable DRL's, but some people will decide not to do it this way. Just disconnect the sensor that is on you're brake fluid reservoir. ever notice that you're drl's don't come on unless you're hand brake is released?
r0lla5XRS is offline   Reply With Quote
Old 03-19-2009, 08:48 PM   #6 (permalink)
mikered30's Avatar
That sensor sounds pretty important, I would not drive around with a sensor unplugged. Wont the brake light or ABS light come on?
Old 03-19-2009, 09:09 PM   #7 (permalink)
it's not that important really, the brake light would come on, you're brakes and ABS will still function. as long as you are sure you have brake fluid in the reservoir, why worry?
Old 03-20-2009, 03:23 PM   #8 (permalink)
'11 Camry
View JasonA's Photo Gallery
You'd rather unplug a sensor and look at a light on the dash every time you drive your car than cut a single wire? I'm not sure I'd say that unplugging the brake sensor is "by far" the easiest way to do it. Cutting the #12 wire takes all of about 20 seconds. And there are no brake lights on the dash either.
And you say "as long as you are sure you have brake fluid in the reservoir, why worry?" That's precisely the point of the fluid sensor. While you're driving, you can't know how much fluid is in the reservoir. If you run over something and it snags a brake line or something, you'd never know it until it were too late. There's no good reason to unplug a safety sensor to avoid a 20 second procedure.
JasonA is offline   Reply With Quote
