Thanks for all the info.
I just finished to have a closer look at the situation, and this is what I have found:
1)After removing the tire form the passanger side, there was a black plastic cover behind.
2)Once the plastic cover removed, the cranckshaft pulley bolt is visible and accessible
3)The bolt is so tight that I was able to rotate the engine by trying to loosen the 17 mm bolt
4)Looks like: I would need an impact air gun + a tool shown on picture to hold the pulley from rotating
5)Also looks like I would need a puller to pull off cranckshaft pulley from shaft
Conclusion: I was so close to it, but so far in the same time.I am going to leave this repair to someone who has all the tools needed, and I am considering to take it to a Toyota service, so they would install an "original" rubber seal, not some poor quality aftermarket piece.
Thanks again for all the help !
Reason: new info
