04 Corolla Rough Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2009, 01:24 PM   #1 (permalink)
View burnsy29's Photo Gallery
Canada 04 Corolla Rough Idle
04 Corolla idles rough and almost stalls. This happens after the car is warmed up. Highway drive is fine, but stop and go driving is a problem. Issue started just a few days ago but appears to be worstening daily. Ideas / suggestions????
burnsy29 is offline   Reply With Quote
Old 03-23-2009, 01:25 PM   #2 (permalink)
Should also add mileage is 205 000 km.
Old 03-23-2009, 06:05 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
I would clean the throttle body and IACV. Any CELs?
mikered30 is offline   Reply With Quote
Old 03-24-2009, 06:24 AM   #4 (permalink)
View dorman68's Photo Gallery
check your intake manifold gaskets, they a very problematic when it comes to vacuum leaks.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 03-24-2009, 07:07 AM   #5 (permalink)
No CEL's which makes things more confusing. Will look into the throttle body and intake manifold gaskets.....where is the IACV?
Old 03-24-2009, 10:00 PM   #6 (permalink)
View User1234's Photo Gallery
Sounds like an intake manifold gasket leak.
I had a similar situation with the idling issue but I had the CEL. Turned out to be the purge solenoid at the carbon canister near the fuel tank.
User1234 is offline   Reply With Quote
Old 03-27-2009, 05:45 PM   #7 (permalink)
05 Rolla
View RawDarkness's Photo Gallery
My car got a bit rough like that almost in the beginning of winter. I took it to the dealership and got it worked on and they found it was my fuel injection. It was an easy fix,,,also i was still under warranty so it was free
RawDarkness is offline   Reply With Quote
