03 trans issue, broken flywheel
My flywheel broke in my 03 Corolla ( 117,000 miles) with automatic transmission. Got one from a junkyard (04 matrix), matched it up and installed it, but when I try to mate the trans to the engine, I run into problems. First the two components don't go together nicely. There is a gap at the bottom that can be closed only after cranking down on the lower two bolts. It seems as if there is a spring between the trans and engine. Second, when I do crank down and pull the two together it locks up the engine. It seems as though the flywheel to torque converter bolts are becoming pinned against the engine. When I loosen the two lower engine to trans bolts a little, I can turn the engine a little bit, but it seems to be hitting what I assume are the flywheel to torque converter bolts. Any suggestions would be appreciated. When my flywheel broke, I had driven it for alittle before parking it. It started leaking trans fluid like crazy. I replaced seal where output shaft is. Could that possibly be source of leak and could that fix it? One of the trans to engine bolts toward the rear had started to back out. I don't know when this occured, perhaps it was partial start of problem. Maybe shoddy technician at dealer. Car was purchased used.
