Help with Transmission Drain and Refill - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2009, 06:20 PM   #1 (permalink)
View bford17's Photo Gallery
Hi guys!!
I need tips and advice on doing the "drain and refill" method on my moms 05 corolla ce auto.
I was thinking of also dropping the pan but i dont know what parts I would need if I do that...
All that I know in doing the drain and fill is that the items that I would be needing are as follows:
1. Toyota Type T-IV transmission fluid
2. Transmission Drain Plug Gasket/Crush Washer
and of course tools...LOL
I know thats like the basic stuff needed to do the drain and fill. I need to know what else do I need if I'm going to drop the pan because I am also thinking of dropping the pan and cleaning the magnets inside..so when I go to the dealer I could get everything needed...
I would really appreciate the inputs guys!
bford17 is offline   Reply With Quote
Old 04-05-2009, 12:06 PM   #2 (permalink)
*bump* really would like an input to this guys..
Old 04-07-2009, 07:26 PM   #3 (permalink)
View wernermeister's Photo Gallery
Wink
well, as a minimum you would need a new gasket....
in most of our corollas the "filter" is actually a steel mesh that needs to be cleaned; some people say there is a filter; I have not seen one.
You also need a "torque wrench", as the torque specs for the pan bolts are very low; easy to overtighten.
Maybe somebody can jump in with the actual in-lbs value for those bolts; I need to do some file searching to find; will get back once I found them.
Good luck
PS: here is a good read in general:
http://www.toyotanation.com/forum/sh...lt#post2612323
wernermeister is offline   Reply With Quote
Old 04-08-2009, 02:05 PM   #4 (permalink)
thanks for the reply wernermeister!! actually I already had read the thread that you posted before I posted my questions...
anyway is it the same method on draining the transmission fluid on the 05 corolla?? I mean is it just the simple drain the transmission and then just fill it up with T-IV fluid where the transmission dipstick go?
just need to make sure about the the procedure...
hope to hear back from you guys...
thanks!!
Old 04-08-2009, 04:05 PM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Yes, it is that easy, easier than an oil change, make sure you have a funnel that fits in the narrow dipstick tube.
mikered30 is offline   Reply With Quote
Old 04-08-2009, 04:17 PM   #6 (permalink)
thanks for the fast reply mikered!! alright then..that means I'm all set to "drain and fill" my moms corolla...I already got the Toyota T-IV tranny fluid..now just gotta make sure my funnel fits the dipstick tube..
Old 04-08-2009, 07:21 PM   #7 (permalink)
mikered30's Avatar
Oh yeah, it is about 3.2 qts per drain and refill. Measure what you take out and check the fluid level when hot.
