2003 rough at higher RPMs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2009, 09:01 PM   #1 (permalink)
View MDs1's Photo Gallery
Dear Forum Members,
One of my 2003 corolla LE seem to be very rough at higher RPMs. For example when accelerating from a stop, I can feel roughness and vibration past 2500 RPM. Also it seems that the car is not smooth at higher RPMs. However, the engine is very smooth at RPMs below 2500 no matter which gear.
I have cleaned the MAF sensor and reset the ECU by disconnecting the battery. Checked the spark plugs and they are clean. The car has 82K miles on it.
Thanks for your help.
MDs1
MDs1 is offline   Reply With Quote
Old 04-05-2009, 12:55 PM   #2 (permalink)
View jonjoe's Photo Gallery
maybe the wheels:tyres could be out of balance or damaged also not a bad idea to get the alignment checked or could be engine mounts going...........
jonjoe is offline   Reply With Quote
Old 04-05-2009, 01:02 PM   #3 (permalink)
Hi jonjoe,
Thanks for your response. I had the tires balanced and wheels aligned only last week. The roughness at higher RPMs is not only when I am driving but also when I press gas while idling.
Anyone else with any other suggestions?
Thanks.
MDs1
Old 04-09-2009, 02:21 PM   #4 (permalink)
View trippinonfohos's Photo Gallery
could be a number of things,
brakes
transmission
CV
driveshafts
engine internals
anything that spins has the potential to be off balance, causing your problem.
trippinonfohos is offline   Reply With Quote
Old 04-09-2009, 04:28 PM   #5 (permalink)
Hi trippinonfohos,
I think I found the clue to the vibration at higher RPMs. It most probably is the exhaust pipe vibration I am experiencing at higher RPMs. I have to check out the exhaust hangers sometime.
Thanks.
MDs
