2003 Toyota Corolla CE Exterior Door Handle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2009, 12:18 AM   #1 (permalink)
View slowjoe69's Photo Gallery
Can someone please tell me how to replace the Left Rear Exterior Door Handle on a 2003 Toyota Corolla CE in full detail. I have already removed the door panel, and i am stuck on what to do next. If someone has the installation instructions that would be great. Please Reply A.S.A.P. Sincerely, Slowjoe69
slowjoe69 is offline   Reply With Quote
Old 04-11-2009, 06:10 AM   #2 (permalink)
View karazy's Photo Gallery
18. REMOVE REAR DOOR OUTSIDE HANDLE COVER LH
(a) Using a torx wrench (T30), loosen the screw and remove
the rear door outside handle cover.
19. REMOVE REAR DOOR OUTSIDE HANDLE ASSY LH
(a) Pull and hold the release plate of the outside handle
frame towards inside of door.
(b) Pushing the outside handle to the rear and then out, remove the outside handle.
NOTICE:
If the release plate is not pulled and held when removing
the outside handle, then the release plate will interfere with
the outside handle and it will damage the release plate.
karazy is offline   Reply With Quote
Old 04-11-2009, 07:25 AM   #3 (permalink)
Adama's Avatar
View Adama's Photo Gallery
Go to www dot 9th gen corolla.com/forum//showthread.php?t=34798 (remove the spaces) and click on the 2004 Corolla Repair Manual. This is the Factory Manual and you can download it. You should be able to find the info that you want.
H&R Race Springs / 09 Xrs Rims / TRD F & R Sway Bar / TRD FSB / Alutec RSB
Avic Z3
/ Tc Center Armrest / Tc HomeLink Mirror / Valentine 1 / ScanGauge II
Adama is offline   Reply With Quote
Old 04-11-2009, 12:26 PM   #4 (permalink)
thanks adama that is exactly what i needed.
